aerodynamic improvements - Page 2 - Fuelly Forums
Old 05-18-2009, 10:10 AM   #11
Originally Posted by maximilian View Post
I keep looking at your picture trying to spot the new addition and then remembering it's part of your signature!
How did you adjustable grille block work anyway? I can't see from the picture how you guide the movable bit.
I made a track out of coroplast and slid the panel in that. Unfortunately the adjustable bit needed to be moved a lot and that shredded the flyline so I just took it off and went with a fixed opening.
Old 06-07-2009, 10:09 AM   #12
GasSavers_Patrick's Avatar
Great work you?ve done there! I?ll have to make an undertray like that myself!
Patrick
GasSavers_Patrick is offline   Reply With Quote
Old 07-01-2009, 02:42 PM   #13
Ranana_Zess's Avatar
Send a message via ICQ to Ranana_Zess
I love anything Aerodynamic, but unfortunately this track gets way too repetitive after a while, it's like they made a Homework version of it.
My favorites: Web Search | Mp3 Music | Free Wallpaper
Ranana_Zess is offline   Reply With Quote
Old 09-05-2009, 01:51 PM   #14
You might not be able to drive with a blocked grill without overheating, but most people here do not have that problem. When you've got enough cooling for 200hp and you're only using 40 of those 200 ponies, you really don't need a lot of air flow to the radiator...
Old 09-05-2009, 08:20 PM   #15
Upper grilles are mostly cosmetic these days, they usually pull air from lower down.
Old 09-07-2009, 11:55 AM   #16
often car makers use the upper grille to make the car look bigger rather than add cooling so they are just cosmetic. On my car the grille is open but it only exposes just 10% of the radiator the other 90% is exposed to the bottom opening.
Old 09-08-2009, 01:48 PM   #17
Banned
any idea on mpg increase with all your mods? where can i get foam gap filler is that a car parts store item?
Old 09-09-2009, 10:11 AM   #18
i'd say half of my improvement isdue to driving technique so the other half must therefore be mods.
Old 09-09-2009, 10:46 AM   #19
Also, don't forget that mods and driving technique complement eachother; they produce a result larger than the sum of their individual results. For example: The wheel skirts help on their own, and coasting helps on its own, but put them together and you can coast further than before...
Old 09-09-2009, 12:29 PM   #20
GasSavers_BEEF's Avatar
spotangeal,
I used weather stripping from advance auto parts for mine. make sure to get the type with the closed cell so it doesn't soak up water and retain it. it has more of a plastic feel to it than a sponge feel. i got the generic kind and it was about $15 for a 20 foot roll or something like that.
*edit* in my garage, you can see it on some of my frontal view pics. it is between my hood and bumper and around my headlights. there is a gap in it so that I can actually open my hood. it is also easily stackable. I put more than needed to be there and then closed the hood on it so that the springiness of it also holds it in place.
Tire sizing odometer modifier? BDC Fuelly Web Support and Community News 10 07-25-2009 08:59 PM
iPhone interface - I missed a fuel up check box is distorted funkd00bi3st Fuelly Web Support and Community News 2 08-13-2008 09:19 AM
85 CRX HF 259,000 mile ron22 For Sale 7 04-03-2008 06:19 AM
Woo! 30mpg! Wyldesoul General Fuel Topics 3 01-28-2008 01:41 PM
How did you first find Gassavers.org? kickflipjr General Discussion (Off-Topic) 17 05-24-2006 07:28 PM
