It's a vortex! - Fuelly Forums
Old 07-18-2007, 02:42 PM   #1
It's a vortex!
I'm about ready to install my commercially available vortex generator (and hope it doesn't suck me into the next dimension) and I now find myself needing to do some tuft testing. All the photos I've seen are of tufts a good 6-8 inches long. Well, I have to define a laminar/turbulence area about 6 inches wide so I need to know if anyone here has used tufts less than 6 inches long. I really don't want to tape several dozen pieces of fuzz on my truck needlessly if they won't work.
If you've ever seen the front of a Dakota, there are several bends and areas where you probably need shorter tufts to define small areas.
Now I gotta figure out a way to video tape it. Wonder how much mileage I'm going to lose with that rig.
Proud owner of Stinkerbutt!
[SIGPIC][/SIGPIC]
-Homebrew front air dam
-Homebrew side skirt
-Torza top bed cover
Old 07-18-2007, 07:43 PM   #2
what now? im completely lost...
Old 07-19-2007, 01:26 AM   #3
Has anyone tried tufts less than the (apparently) usual 6 inches long?
[SIGPIC][/SIGPIC]
Old 07-19-2007, 03:39 PM   #4
I said the heck with it and put 4 inch tufts on the truck; black tufts with black tape. Hopefully nobody that has a pretty red light on top of their blue car will notice and ask me why the heck I have string taped all over my truck.
The idea comes from the manufacturer to find where the laminar flow breaks off the body in order to place the vortex generators.
[SIGPIC][/SIGPIC]
Old 07-19-2007, 04:42 PM   #5
Sweet. Happy tufting!
Old 07-20-2007, 04:23 AM   #6
jwxr7's Avatar
when i did mine, I used 3-4 inch strings. They seemed to do the job.
Old 07-22-2007, 09:40 AM   #7
Well, I did use 4 inch pieces from Ann Arbor to the shack in Gaylord with some odd results.
First, I found no place on the hood or front of the truck where there is turbulence. The things just went straight back. Unless I was following another vehicle and then they'd move side to side about a half inch.
Next, I'm going to put them on the bed cover. I know I have turbulence back there.
[SIGPIC][/SIGPIC]
Old 07-22-2007, 02:29 PM   #8
Yep, hood and front are usually boring. The wheel openings and the rear are more interesting. And for you, the bed cover.
Old 07-25-2007, 12:18 AM   #9
sonyhome's Avatar
The side to side movements you noticed behind a vehicle could be from the turbulences.
If you go to airtab website, they model the wake / airflow behind a truck as rolling -erh- tornadoes comming from one side after the other...
As far as I understand, vortices are used to virtually extend a surface, so that the laminar flow keeps going after the surface has ended.
[I may be wrong but i'll keep going ]
Behind a car, like a spoiler, it avoids having the laminar flow from wrapping back down on the trunk. It creates an air hole behind around which the laminar air flows, hopefully to meet gracefully. The goal is for the virtual shape of car+hole to be similar to a teardrop.
Between parts of the vehicle that don't have a nice laminar flow, the vortices can help the laminar air skip from one surface to another. This creates an air depression, but avoids the laminar flow to just hit the next surface head on and break into a massive turbulence.
So in conclusion, you could try to use vortex generators to replace your failed attempt to do a spoiler on the top of the cab. With some luck it could extend the airflow past your bed, and so that's where you want your tuft.
What to expect IMHO:
The tuft will shake severely and fuzz where the airflow contacts the bed cover. Before that the tuft should be not moving or moving slowly randomly. If you achieve laminar on your cover, they'll line up, but that's unlikely, even with the vortex generators. Instead I suspect you'll see all the tuft move lazylly around as they would all be in the quiet air bubble. The laminar flow should be around that bubble.
The only exception where I'd expect turbulence is where the sides of the bed, where the air probably would enter wrapping around the sides.
The bubble should become a virtual bed cover like the wood one (I think) you were thinking of putting which slopes down from the top of your cab to the end of the bed.
Old 07-25-2007, 04:57 AM   #10
If the air tabs do anything that they claim to do, then you should be able to see a huge difference in the air flow on your bed cover with and without the tabs. AND, it's easy to shoot video of that surface...
fuelly can't do math CactusBob Fuelly Web Support and Community News 1 12-04-2012 03:39 AM
City vs Highway tracking now a car setting errorik Fuelly Web Support and Community News 6 05-31-2011 08:32 AM
Aerodynamic auto designs, past and present, and their possible implications The Toecutter Automotive News, Articles and Products 12 02-10-2007 12:04 AM
Gassavers Dictionary of Technical Terminology krousdb General Discussion (Off-Topic) 7 02-11-2006 05:30 PM
Fuel economy links kickflipjr General Fuel Topics 0 11-27-2005 11:00 AM
