Low rider - Page 2 - Fuelly Forums
Old 04-09-2009, 12:32 PM   #11
Stick the right controls on there and you could have an active suspension!
co de pen den cy
Function: noun
Date: 1979
Old 04-09-2009, 01:32 PM   #12
Remove some of the leafs and install air shocks?
regards
gary
Old 04-09-2009, 01:42 PM   #13
That's what some of the Audis use and they can adjust height, right?
co de pen den cy
Function: noun
Date: 1979
Old 04-09-2009, 01:52 PM   #14
My 1987 Cadillac had air shocks and an automatic leveling system. Well, by the time I had it, all that was left was empty air shocks. I installed schraeder valves, mounted in the wheelwells so I could open the trunk and pump them up. I emptied a can of fix-a-flat into them then went to the gas station to use their compressor. There, I pumped in enough air for a little bit of rake. I drove out, went over the bump to enter the road, the shocks went "pop"...and I left behind a puddle of fix-a-flat.
Anyway, there's an endless array of products for adjusting the height of full size pickups, including loads of air bags and such, but they're all very expensive.
Old 04-09-2009, 05:44 PM   #15
Jetta90GL's Avatar
Originally Posted by maximilian View Post
Interesting that his air dam has a gap in the center. Guess he figures air must be going more sideways than up. Or it was just hard to do.
I just didn't finish it. I had planned on that being a door for cooling the radiator, while the grill was completely blocked. I ended up taping a piece of coroplast there, which blew off half way through the winter. Right now I have the air dam removed to adjust my front wheel alignment. I'll be fixing it up more before I put it back on.
Jetta90GL is offline   Reply With Quote
Old 04-09-2009, 05:50 PM   #16
Thanks for the info! Had me scratching my head looking for a deeper reason!
co de pen den cy
Function: noun
Date: 1979
Old 04-09-2009, 08:14 PM   #17
theclencher's Avatar
I don't know if lowering will help enough for you to detect it. I lowered my car about 2" and if you didn't know the date I did it, you'd never be able to detect it in the gaslogs.
I'd be more inclined to think a tonneau/cap and/or airdam would be more fruitful, not to mention easier and cheaper.
Tempo/Topaz:
Old EPA 23/33/27
New EPA 21/30/24
F150:
New EPA12/14/17
Old 04-10-2009, 03:06 AM   #18
Well, it could be more useful in a full size pickup with those big axles catching wind than in a car where all you're doing is bringing the flat bottom closer to the ground.
Old 04-10-2009, 03:11 AM   #19
Yah, could be.
Tempo/Topaz:
Old EPA 23/33/27
New EPA 21/30/24
F150:
New EPA12/14/17
Old 04-10-2009, 03:12 AM   #20
A deflector forcing the air smoothly under the axle could have a lot of the same result.
co de pen den cy
Function: noun
Date: 1979
Data/Chart Discrepancy PTH Fuelly Web Support and Community News 3 07-02-2010 07:14 AM
SMS fuelup went to wrong car todd Fuelly Web Support and Community News 4 03-17-2010 02:31 AM
How does Automatic Tranny choose? GeekGuyAndy Transmissions and Running Gear 5 08-13-2007 04:05 AM
Hypermiling Auto Trans w/ Tach brucepick Transmissions and Running Gear 4 04-12-2007 11:32 AM
