08-16-2006, 11:30 PM
My Yaris came stock with the antenna embedded inside the rear window. I wonder what the FE improvement is.
Using my new Scangauge in an unscientific test, I noticed a ~10% FE reduction by sticking my arm fully outside the window (50mpg to 46mpg). This was at about 60 mph on cruise control. An antenna is hardly the same as an arm but I can see why it would be bad, being in such a high velocity air stream.
08-17-2006, 05:45 AM
What a coincidence - I was looking at my antenna yesterday while riding past the car on the beater bike ... and wondering why I don't take it off.
Mine's mounted in the same location, but there isn't even a radio on the other end of the cable. I have the original "blank" where a radio should be. (And I've checked: there are 4 speakers installed from the factory. But no radio. Strange. The only option the car came with: side moldings.)
I guess until I get around to putting a radio in, I could take my antenna off too.
This one's in that category of changes where the effect is indetectible, yet logically, it's better without than with.
08-17-2006, 08:34 AM
Darin, I say you go for it. Life's no fun with comercials anyway.
Ninja edit: oh snap, my old tank fell off the 90 day,
08-17-2006, 08:37 AM
Woohoo for the 90-day average!
08-17-2006, 08:40 AM
It must've been removing the antenna last night that made my FE jump so high,
08-17-2006, 08:59 AM
Or did you install one of those gold-plated PCV valves and not tell anyone?
08-17-2006, 09:00 AM
I'm pretty sure it was the wire tuck, been doing pretty well since then,
08-17-2006, 11:35 AM
While your at it. You better take out thouse non used speakers. That will drop 7kg off your car and improve your gas milage about as much as removing your antenna.
2008 EPA adjusted:
08-17-2006, 01:08 PM
#19
what nonused speakers? You can hear my blasting daft punk from a block away.
08-17-2006, 05:42 PM
#20
I am talking about metro's car. He doesnt have a radio.
2008 EPA adjusted:
