Java Help Please - Fuelly Forums
Old 10-08-2010, 07:49 AM   #1
Java Help Please
Java is the problem.
Old Java is blocking new Java from working with streaming stock charts.
I have a bunch of Java's in the "add - remove" list but when I highlight them there is no 'remove' button.
How do I remove the ones I can't remove?
Old 10-08-2010, 11:52 AM   #2
Re: Java Help Please
It is likely that the old ones without a Remove button are merely old entries in the list that don't represent actual software that's installed.
Use Revo Uninstaller. It will likely be able to remove them whether they're stubs or actual installations. There is a free version and a paid version; the free version is fully competent to do the job.
http://www.revouninstaller.com
However, the symptom that started you on that journey is that you have two conflicting versions. Most likely, you have Microsoft Java and Sun Java. I've never had Microsoft Java but I imagine it may be difficult to uninstall as well as non-functional...that's the sort of thing Microsoft usually screws up badly. See if you can get rid of all versions of Java, then install the latest Sun Java.
http://www.java.com/en/download/manual.jsp
These links look like they might help in removing Microsoft Java.
http://www.helpwithwindows.com/WindowsXP/howto-21.html
http://www.bleepingcomputer.com/tuto...utorial97.html
It appears to be an involved, manual process with the potential to break stuff, but it is also necessary. Microsoft apparently discontinued their version of Java years ago and does not offer updates to keep it functional and secure.
Old 10-09-2010, 03:59 PM   #3
I got some answers. Having buddies willing to help is a good, cheap, way to fix a problem. I am thankful.
Click to start a chat with a Java support Expert.
Explain your issue and get a quote. Most problems cost about $50 to fix.
When you're ready, hire the Expert and watch them fix your problem.
Why I didn't utilize the fix at Java. Not giving things away is why Larry stays rich
Revo Uninstaller Pro - Uninstall Software, Remove Programs easily
Java Downloads for All Operating Systems
Remove Microsoft Java Virtual Machine and Install Sun Java - HelpWithWindows.com
Your wish is my command.
Java Runtime Environment (JRE) - Java Console missing, Add Remove button missing, How do I manually reinstal
I use netdania:
Forex Charts | Currency Charts - free
seems to work well with Win 7 and IE8
What's your definition of "old Java"?
How To Uninstall Java
In order to fully remove and uninstall Java from your computer, you can do two things.
1 - You do it manually and then directly editing the registry, and removing the installation files.
2 - You use a Java Uninstaller to do it automatically.
I highly recommend you that if you are looking for a Java removal plan, that you use option two. Doing it manually has a couple of huge downsides. You'll not only have to remove Java from your drivers, but you've also got to go inside your registry to remove any left over files and this opens you up to potential registry corruption. Unless you are very familiar with working inside the registry itself, you might want to use an "uninstaller".
Java Uninstaller
There are thousands of 'uninstaller' programs but many simply fail to work properly. The best of the bunch is called Perfect Uninstaller. The Perfect Uninstaller will help you to fully remove Java by doing three things:
1 - First, the Perfect Uninstaller uninstalls Java installation and program files,
2 - Commences a scanning of both your registry and your drivers to find out if there are any left over files,
3 - Once the scan has been completed, the uninstaller will start deleting any additional files that have been found.
HTH. Good luck.
And
Don't forget to do a drive by picture of someone drinking java - your thread wouldn't be complete without it...
Search by Area... MatrixDom Fuelly Web Support and Community News 6 06-08-2014 06:30 PM
iPhone WebApp? Billie Fuelly Web Support and Community News 11 08-09-2008 11:59 AM
Air deflector vs. Full aero? DrivenByNothing Aerodynamics 5 04-11-2007 11:14 PM
