WTB - 5 wire (non-CA) VX O2 Sensor - Fuelly Forums
Go Back   Fuelly Forums > Marketplace | Buy, Sell, Trade > Wanted to Buy
Old 04-29-2007, 04:39 PM   #1
Getting the ECU soon from the for sale board.... now need the rest of the stuff...
also, anyone have any wiring harnesses to match?
lca13 is offline   Reply With Quote
Old 04-29-2007, 06:37 PM   #2
GasSavers_TomO's Avatar
Check on Ebay L1H1 search for the L1H1 O2 sensor or Oxygen Sensor Warehouse if you don't find that anyone has a good used one for you. Both places have the new ones for ~$180.
As for the matching Harness.... there is a seven pin connector on the front end of 94+ Integras that resides just under the upper radiator support that works with the L1H1. It's the connector to the left of the number 14, it's part of the "Cabin Harness"
If you don't have a junkyard near by that will let you cut up a wiring harness, I do have a spare connector (OEM cut from a VX harness with ~8" of wire on it) for the L1H1 that I can sell you.
Honda Civic VX Info/Links
Old 04-29-2007, 07:42 PM   #3
kwtorbe's Avatar
Good luck with your search.
I have a somewhat related question about my HX....
My '97 civic HX has an L1H1 5-wire on it.... I know someone here told me it should have the L2H2. I have had several check engine codes indicating something wrong with my 5-wire in the past. However, my HX does enter lean burn and I do get about 45mpg. Would I see any improvement running an L2H2?
kwtorbe is offline   Reply With Quote
Old 04-29-2007, 08:08 PM   #4
the books show 36531-P2M-A01 as the part number for your HX. It is a completely different number for the VX. I found a cross reference chart HERE showing the Bosch numbers and most other manufacturers' numbers.
After a quick search though, some sources say that the L2H2 is a newer replacement for the L1H1. Either way, I'd try and get an L2H2 for your HX.
Old 04-30-2007, 05:49 PM   #5
kwtorbe's Avatar
Cool, well then I will have a used L1H1 as soon as I find an L2H2...
Old 05-06-2007, 05:14 PM   #6
I am also looking for a L1H1 for my VX...how many miles on your used L1H1?
GasSavers_James is offline   Reply With Quote
Old 05-06-2007, 07:25 PM   #7
My ECU, L1H1, and spare O2 connector is shipping out Monday to lca13, sorry, James
Old 10-15-2007, 12:57 AM   #8
garyhgaryh's Avatar
Do you have another of those spare connectors to sell?
Gary
garyhgaryh is offline   Reply With Quote
Old 10-15-2007, 07:55 AM   #9
I do have a spare connector, but I have plans for it....What I have found though is that there is a connector on the 94-97 Integras that can be used for a connector for the 5 wire 02. If you have a junkyard nearby that will let you hack a chuck of harness off:
I used connector #3 IIRC. It is the same plug that they use for the 5 wire O2. It sits up under the radiator support on the integra. It's basically the biggest plug in that area. I hacked off about two feet of wire with mine so I can extend my O2 position when I got my header installed on my VX.
Odometer help/suggestion waterboysh Fuelly Web Support and Community News 10 12-14-2012 03:38 PM
Conversion successful Matt Timion Fuelly Web Support and Community News 12 05-18-2006 02:24 PM
If this don't get you pulled over then I don't know what will. (PICS) Compaq888 General Fuel Topics 13 04-12-2006 08:53 AM
Electric panel heaters GasSavers_JustMe General Discussion (Off-Topic) 0 01-03-2006 03:43 PM
