has anyone tried this? - Fuelly Forums
Go Back   Fuelly Forums > News and Articles > Car Reviews
Old 09-29-2007, 02:20 PM   #1
just what the title says. http://www.thegassecret.com/?gclid=C...FQqgYgodoz85Eg I'm a bit skeptical myself.
light-foot is offline   Reply With Quote
Old 09-29-2007, 02:51 PM   #2
GasSavers_Red's Avatar
Meh acetone or seafoam in a bottle.
Old 09-29-2007, 03:13 PM   #3
oneinchsidehop's Avatar
Well, they use a Fox news special to show their credibility... that's almost as good as a testimonial by the Alligator Boy or Bigfoot.
What is seafoam?
Mike
_______________________________________________
"If you want to save gas I suggest you permanently remove the drivers seat and steering wheel. That seems to help." -Oscar Halverson
oneinchsidehop is offline   Reply With Quote
Old 09-29-2007, 03:28 PM   #4
A combustion chamber cleaner.
http://en.wikipedia.org/wiki/Seafoam
Old 09-29-2007, 04:06 PM   #5
ha. I had a feeling it's just another gimmick.
Old 09-29-2007, 04:45 PM   #6
Hmmm.... thanks for the link.
Now if you had a 3rd hand Subaru with a questionable (non-existent probably) maintenance history would that be worth a shot?
Mike
Old 09-29-2007, 05:37 PM   #7
|V3|2D
thisisntjared's Avatar
sea foam works. its just a cleaner. i use it through the brake booster to clean out the intake manifold. it helps smooth the idle and give back 1/3 of a mpg.
with my wifes old car (92 mitsu. galant) half a bottle of sea foam saved it a trip to the mechanic to diagnose stalling and a bad idle.
Old 09-29-2007, 08:09 PM   #8
Seafoam
Just do a search on Seafoam here...
I can attest that it significantly cleans-out the gunk and carbon from the engine's top-end. It's a yearly tradition to smoke-up the neighborhood with a good old-fashioned Seafoamin'
Also, my folks have a '93 Chevy Truck that overheated and cracked the rad. It wouldn't turn over, so it was figured to have a trashed engine. Upon recommendation of a certain family member Seafoam was dumped directly into the cylinders by removing the spark plugs.
After sitting for a few hours, the plugs were replaced and it started up and ran smoothly. The stuff works great as a maintenance item or to free up sticky engine parts. Using it to improve FE as an additive, has yet to be proven as statistically significant.
-RH77
Old 09-29-2007, 09:48 PM   #9
I'd do it, another good trick is slowly, as in very slowly, use water instead of seafoam to steam clean the head. Not as big of a smoke cloud but still effective
Old 09-30-2007, 03:11 PM   #10
|V3|2D
yea i would just empty a spray bottle at the throttle body as i opened it by hand. i never knew how well it worked though.... seafoam definitely worked by cleaning out the intake side of the head and manifold.
