Any truth to HHO - Fuelly Forums
Old 08-08-2008, 12:48 PM   #1
Smile Any truth to HHO
I know we cant build a hydrogen gen to produce enough for a car out of water at this point.I was wondering if the HHO produced at say 5LPM of it would actually oxidize the gasoline it was mixed with in the combustion chamber sort of like NOX does? since they clearly produce hho (the homebuilt reverse type batteries that you feed 15 amps into) I know they dont produce enough to run the car on, but surely this must help improve the mileage ,they seem so adamant about it.I wanted to ask in here since this is not an HHO forum so I figured you guys would be unbiased,any ideas>Marvin thanks so much in advance
mrjetskey is offline   Reply With Quote
Old 08-08-2008, 01:24 PM   #2
GasSavers_BEEF's Avatar
if it didn't work, they wouldn't sell it on ebay....just look how good the tornado is selling and the electric supercharger. (note: sarcasm)
truthfully though, anyone that has reported any gains that I consider reputable are seeing very neglegible gains which aren't worth your normal joes time or money. most are just heating water and burning electricity.
and maybe I am a little biased, also (just to let you know) there is an HHO section on this forum as well. you may get more positive feedback there.
Old 08-08-2008, 01:33 PM   #3
The Tornado is a piece of junk. I bought one for Rusty years ago... I now have an expensive, funky shaped piece of stainless steel sitting on the garage shelf. Maybe I shouuld cut it up and use it to make an HHO generator.
Old 08-08-2008, 02:28 PM   #4
I'm a pretty big skeptic when it comes to this stuff. BUT I made one of these from a piece of sheet metal one day and can't say it was totally worthless.
Up top it was a light restriction, at anything under 80% throttle the 'vortex' created by it is worthless because of the throttle body, but at a wide throttle opening I seemed to have felt a difference in the low-end feel of the car.
Maybe I should strap my car to the dyno and see wtf... Been meaning to do it for HHO anyways.
- Kyle
Old 08-08-2008, 03:18 PM   #5
Well, it was being sold as a fuel saving device, and the only thing it did was take ~$75 out of my bank account.
Old 08-09-2008, 01:46 PM   #6
the reality is that most (if not all) of the cars on this site haven't seen WOT in quite some time. I don't think mine has seen more than half throttle so it is no more than a restriction in the line.
$75 for a restrictor plate, not a good deal
Old 08-09-2008, 03:52 PM   #7
My car sees WOT probably more than 50% of the non-highway time on my commute. It's getting me great mileage.
WOT at low RPM is great...
Old 08-09-2008, 06:30 PM   #8
yea but my WOT throws me into open loop.
not all of us have the lugury of the wide band O2 sensor.
am I jealous.........yes very
Old 08-09-2008, 07:50 PM   #9
WOT on a diesel doesn't take your vacuum away.
Old 08-09-2008, 08:40 PM   #10
I use larger throttle openings to accelerate quite briskly. Seems to work wayyyy better than trying to granny it up to speed through the TC slush and wishful thinking. However, on the tornado front, while I can see circumstances where the theory works out, they don't in practice come up often. Any 2 bank motor feeding off a single intake... well it's fighting factory "swirl" on half of it, and you've got a 50% chance of being wrong on a single bank motor. And then when you're right, the factory swirl might have been done well enough in the first place that you're fighting for the last 10th of a percent in 10% of the driving range.
new epa or old epa in the garage?> thisisntjared General Discussion (Off-Topic) 7 05-22-2008 07:09 PM
A shot with a mix... GasSavers_SD26 Diesels 23 03-13-2008 05:20 PM
