Odometer View Not Working in Gas Cubby 2.6 - Fuelly Forums
Go Back   Fuelly Forums > Fuelly Community Support > iOS | Fuelly Mobile
Old 09-17-2014, 09:28 AM   #1
I updated to Gas Cubby 2.6 and the odometer view has numbers that are invisible now. If you drag your finger in the right place you will see the odometer text change, but you cannot see the wheels to spin them to the correct value. Anyone else see this?
RandallC is offline   Reply With Quote
Old 09-17-2014, 04:48 PM   #2
RobertV's Avatar
What device and version of iOS are you using?
Can you provide a screenshot?
Old 09-17-2014, 06:23 PM   #3
iPhone 5
iOS 7.1.2
If I set the currency to not use the number pad then I can only see the cents. If the odometer is set to not use the number pad then I can only see the tenths of miles. So the digits to the right of the decimal place show, but not the digits to the left.
Old 09-17-2014, 07:09 PM   #4
RobertV's Avatar
This is the first I've heard of this specific issue.
Have you tried deleting and reinstalling GasCubby?
Old 09-17-2014, 07:16 PM   #5
I have not tried that yet. I didn't want to lose the data when I delete the app. I have backed up the phone to iTunes, so do you think it is safe to delete the app on the phone and reinstall?
Old 09-17-2014, 07:59 PM   #6
RobertV's Avatar
Have you set up sync?
Old 09-17-2014, 08:03 PM   #7
yes, and it shows my last successful sync was at 7:32am on 9/17/14.
Old 09-17-2014, 08:09 PM   #8
RobertV's Avatar
Actually, funny enough I was just able to replicate this problem.
I'll forward this along to our developer.
Good catch!
Old 09-22-2014, 11:10 PM   #9
RobertV's Avatar
RandallC,
If you haven't already, please update to v2.7 and report back if this issue continues on your device. You can post here: http://www.fuelly.com/forums/showthread.php?t=16883 so we can keep all the reports together.
Thanks!
Edit- Although, just double checked the spin-wheel input and we're still having trouble with it. Mainly iOS8 not playing nicely, but we're working on it. You can switch the input (it's set by default with 2.7 though) to Number Pad so you have a working entry method.
Old 09-23-2014, 08:44 PM   #10
I do still see the problem in 2.7.
