Problem with importing CSV file. - Fuelly Forums
Old 08-20-2016, 10:48 AM   #1
Exclamation Problem with importing CSV file.
So I've been using aCar for about 5 years now (love the app) and so i exported all my app data to an CSV file so i could edit things like tags, station names. Just wanted to clean things up a bit. Fast forward a couple of hours and i'm ready to export. I export the file from excel back to a CSV file and put it on my phone to import in.
Doesn't work. Not sure what I'm doing wrong but it won't let me import.
It says, "Could not import the data! The selected Date Format (or Time Format if any) does not match with the date/time values in the file you're trying to import".
How do I fix this?
Crypto_Smack is offline   Reply With Quote
Old 08-20-2016, 12:01 PM   #2
I have to edit the CSV.
agdodge4x4 is offline   Reply With Quote
Old 08-20-2016, 05:48 PM   #3
RobertV's Avatar
Excel often times changes the date format to fit your specific display preferences. In most cases here in the US, I think our default is MM-DD-YYYY. So when you Save your changes, it actually saves the dates in the format you have your display settings set at.
aCar exports it in YYYY-MM-DD I believe.
So either edit the original CSV (without converting it to .xlsx) or just ensure your date is formatted like the original .csv export (double check, but I'm pretty sure it's YYYY-MM-DD).
Alternatively, import it as a Plain CSV and just map each field appropriately.
Old 08-20-2016, 11:19 PM   #4
Ah. I found out what the issue was.
Issue: I'm an idiot lol.
I exported it from aCar, edited it, then tried to give it back as a CSV file but what i should of done is giving it back AS an aCar file. Did that and it worked.
YAY!
So this thread can be closed. Thanks for your help. Can't wait for the aCar/Fuelly merge
Old 09-01-2016, 09:55 AM   #5
I'd like to import historic information into Fuelly for my other two vehicles that I originally started tracking back in 2008 with MyMileMarker (My Mile Marker) way back in the day before moving to GasCubby and now Fuelly.
I have put the data for my Audi and Jeep into the proper CSV format as described here: Importing Your Data Into Fuelly , but where exactly do I go to import it?
tdlundin is offline   Reply With Quote
Old 09-01-2016, 07:27 PM   #6
RobertV's Avatar
You can import it by clicking the little icon in your vehicle profile. Here's the FAQ with more info: FAQ: How do I import fuel-up data?
Old 09-02-2016, 03:28 AM   #7
Cool, I found the little excel sheet looking icon ( ) it worked out perfectly. Thank you.
Old 09-22-2016, 03:43 PM   #8
Fuelly SUCKS
I have had Gas Cubby for 5 or 6 years and suddenly today it's changed on my phone to Fuellyy and my data is gone. I emailed support and all i get is a csv file and no way to get it into my account, even online. What a bunch of crap.
Hembrey is offline   Reply With Quote
Old 09-22-2016, 06:09 PM   #9
Wrong thread and hit them up, they have workarounds for this to get your data back.
Old 10-27-2019, 05:53 PM   #10
I am having the same error, it doesn't matter what format the date is in, it returns
Error
The fuelup date must be a date before 2019-10-30.
JohnnyQ is offline   Reply With Quote
