new owner of a 88 crx si - Page 2 - Fuelly Forums
Old 01-02-2007, 02:34 PM   #11
The VX got worse FE than the CRX HF. They moved began moving away from FE with the VX, hence the shorter gearing than the hf.
Old 01-02-2007, 02:43 PM   #12
pyramid_head's Avatar
Send a message via Yahoo to pyramid_head
So i shouldn't trust edmunds and sites like that... right? it' reads that the hf gets 49 city/52 hwy... then again that's with its stock HF engine. With a 92-95 vx D15z1 engine (48 city-55hwy rating)/L3 hf transmission... i'm guessing i will see a difference in FE. That, and everything just gets heavy after 1990.
I'm still confused in what engine i should get now... lol.
www.onetruth.com
pyramid_head is offline   Reply With Quote
Old 01-02-2007, 02:47 PM   #13
okokokok.... should i just get a d15z1, obd1 conversion for the p07 ecu, and an HF transmission?
www.onetruth.com
Old 01-02-2007, 03:21 PM   #14
oh... lol.. thanks SVOboy. I just read your 1st post in his thread. lol.. thanks. i wonder if the D15z1 is a direct bolt-on to a crx... anyone know?
www.onetruth.com
Old 01-02-2007, 03:46 PM   #15
it's a d series engine, it should just bolt up.
white90crxhf is offline   Reply With Quote
Old 01-02-2007, 05:48 PM   #16
What about the crx si axels. Would they bolt up nicely on a HF transmission?
www.onetruth.com
Old 01-02-2007, 09:07 PM   #17
Direct bolt in, less wiring. Axels will work with the transmission, they're all the same on the tranny side, but the HF are smaller on the brake side, which doesnt matter in this case.
Old 01-02-2007, 09:47 PM   #18
Matt Timion's Avatar
The D15b.... is that the j-spec stg 3 engine, or is that the 62 hp engine?
The d15b, as it is known in japan, is actually 3 different engines.
1) d15b vtec - regular vtec, 120hp-ish
2) d15b vtec-e - our little friend, 62hp w/o vtec. 92 with
3) d15b 3 stage vtec
When you buy it, you have to specify that you want the d15z1. They should do you well.
The SI axles will bolt right up. The HF transmission will bolt right up too. These engines usually come with exhaust and intake manifolds. Mine came with a clutch and flywheel. It'll also come with a bunch of sensors and probably most of your pigtails for your new harness.
You can get a custom obd0->obd1 conversion harness at www.rywire.com for around $130. Be sure to tell them what you're doing. In your case, you're going from pm6 to p07. If you have the money, I'd actually recommend you acquire a civic VX wiring harness somewhere and just send in your two harnesses. For a bit more money they'll send you back a plug-n-play harness. No wiring headache.
Don't forget that you'll also need the EGR Control box, which is unique to the Civic VX. You should be able to get those cheap on honda tuner sites from people who got rid of their d15z1.
Old 01-02-2007, 09:59 PM   #19
Thanks everyone for your input. i just downloaded the honda 92-95 manual from hondahookup.com and the crx repair manual as well just for a piece of mind. Matt, so i can actually send in a vx and my 88 crx si harness so i can avoid a nightmare and directly plug it in a p07.... wow.. sounds nice.
Also, how does $50 for a P07 ecu sound? is it a good bargain, or can i find the cheaper?
www.onetruth.com
Old 01-02-2007, 10:03 PM   #20
You can find cheaper for a p07, I;d shoot for around 30 shipped.
Tags in SMS messages elliottcable Fuelly Web Support and Community News 1 12-15-2011 12:28 PM
How to change fuel type JayHoe Fuelly Web Support and Community News 3 06-15-2011 12:14 AM
An Inconvenient truth zpiloto General Discussion (Off-Topic) 68 03-12-2009 11:45 AM
The Honda Fit GasSavers_DaX General Fuel Topics 54 05-13-2006 12:52 AM
adding batterys bagpipe goatee Electric and Solar powered 3 02-06-2006 04:03 AM
