40.8mpg on 92 Civic VX - Page 3 - Fuelly Forums
Old 12-15-2007, 07:03 PM   #21
No, the MAP sensor bolts to bracket #8 on the top of the intake manifold.
GasSavers_broadwayline is offline   Reply With Quote
Old 12-16-2007, 05:11 AM   #22
Danronian's Avatar
Originally Posted by TomO View Post
That diagram shows where that little vacuum sensor should be and the hoses that should connect to it. And yes, the top of it is supposed to come off that easily.
edit:
It's # 11 in the diagram.
#15 is the MAP which bolts onto the top of the throttle body. Bracket 8 is for the throttle cable.
Old 12-16-2007, 02:13 PM   #23
VX trainee
OK, after a little more investigation today, the little tab is there on the intake manifold for #11 to bolt to, but it's not drilled or tapped. That seems weird to me. Maybe I'll drill and tap it later on, when I'm feeling adventurous.
4bfox is offline   Reply With Quote
Old 12-16-2007, 05:16 PM   #24
GasSavers_TomO's Avatar
edit:
Dan is correct on all accounts. The item with the "top hat" that we are talking about is called the purge solenoid. It controls the vacuum going to the charcoal canister that resides under the fuel filter. The top part is just a filter for when the solenoid is not triggered.
That is weird that it isn't drilled or tapped...Your intake manifold is only about 2" in diameter after the throttle body, correct?
Honda Civic VX Info/Links
Old 12-17-2007, 04:22 AM   #25
VX trainee
That makes sense. Yes....no hole in the tab. I checked my "spare" engine, it has one.
Old 12-17-2007, 07:14 AM   #26
I am suspicious of a swapped intake manifold then if the tab is not drilled and tapped for the Canister Purge Solenoid.
This is going to sound really weird, but can you get a picture of your throttle body from above while holding a golf ball above the manifold for size comparison?
I know a golf ball is just small enough to get stuck in a VX throttle body.
Old 12-17-2007, 11:41 AM   #27
VX trainee
Now you've got me paranoid....I looked at the left front of the engine....D15B.
Shouldn't it be a D15Z?! Has the "Honda VTEC-E" valve cover, which means nothing...other than I may have been screwed.
Old 12-17-2007, 01:08 PM   #28
After glancing through some of your previous posts, it sounds like you have a JDM D15B transplanted into your VX. Don't worry too much yet. There was a JDM equivalent motor to the D15Z1 in Japan. The engine code was D15B (unfortunately all the 1.5L engines in Japan were stamped D15B). Best way to tell if you have the ETi motor (that was the model name I believe that had the equivalent motor) is to pull the valve cover and check for roller rockers:
Bad picture but the only one I could find right now.
Also check for an EGR Valve on the intake manifold near the distributor.
Old 12-17-2007, 01:49 PM   #29
VX trainee
Well that makes me feel better.....I think I've seen the EGR valve you mentioned. Goes along with the story I got from the seller.."VX engine-imported from Japan".
I'll make sure it has the roller rockers, too. Obviously one difference is the absence of the Canister Purge Solenoid. Any other differences from the D15Z1 that you know of? Thanks for your expertise, BTW!
Installed 195F Coolant Thermostat ... Reset ECU? cfg83 General Maintenance and Repair 13 04-06-2011 11:54 AM
Weight reduction - not always good? landspeed General Fuel Topics 59 02-29-2008 06:21 PM
2006 Toyota Camry LE rh77 Car Reviews 0 01-24-2007 07:17 AM
Finally got some LRRs rh77 General Fuel Topics 4 10-03-2006 08:16 PM
"Lean Cruise" ECU Modification Thoughts GasSavers_scostanz General Fuel Topics 12 07-11-2006 04:36 AM
