Accuracy of MPG displays? - Fuelly Forums
Old 01-08-2011, 07:22 AM   #1
I know I've seen somewhere on the forums about the accuracy of the onboard MPG calculators in cars, but can't locate it right now.
Seems that they have an error of +/- 7% as I remember...is that right?
My '07 Camry has an electronic MPG calculator, and I will be starting a gas log to compare to it. Just wondering if anyone here has had any real world experience as to how close these onboard displays are?
Thanks!
Ms.V.X. is offline   Reply With Quote
Old 01-08-2011, 08:30 AM   #2
Re: Accuracy of MPG displays?
It varies heavily from one vehicle to the next.
It's definitely worth keeping a gas log, regardless of an onboard MPG display. You get all the data, it gets put on a graph for you, you get to keep other notes (like maintenance), and it becomes easy to track and compare.
Old 01-08-2011, 12:22 PM   #3
Site Team
On my wife's Buick, it's consistently 8% too low and we always use more fuel than shown on the display.
-BC
Old 01-08-2011, 01:30 PM   #4
benfrogg's Avatar
Tire size can play a large role in accuracy. Even if the gauge was accurate to start with, a slightly different tire from stock will reduce it's accuracy. In fact, I imagine new deep tread tires to very worn out tires would have an effect.
I like that my gauge can be adjusted manually. (MPGUINO) That's really the only way to get close.
B
Old 01-08-2011, 04:27 PM   #5
SL8Brick's Avatar
My Audi's display will occasionally show over 200mpg while decellerating/coasting downhill...I've always found that kinda funny.
SL8Brick is offline   Reply With Quote
Old 01-08-2011, 05:53 PM   #6
It's probably indicating DFCO.
Old 01-10-2011, 09:59 AM   #7
Yeah, mine too.......downshifted going down the mountain mine reads 9999mpg......it's hilarious ... DEFCO........haha
Then I pay dearly going back up later...(no need to discuss that...haha)
Dave
GasSavers_GasUser is offline   Reply With Quote
Old 01-11-2011, 10:18 AM   #8
kamesama980's Avatar
agreed, depends on the car, the method they/you're using to read it, calculate it, and display it. check yours at the pump a few times to figure out the margin for error and how to correct for inaccuracy.
-Russell
Old 01-14-2011, 08:49 AM   #9
Martinjmpr's Avatar
My guess is that most factory-installed MPG displays cannot be calibrated. My 99 4runner doesn't have one but I put in an Ultra-Gauge (which is similar to the Scangauge in that it gets info from the OBDII port and calculates MPG.) I had to calibrate it a couple of times (first for distance and then for MPG) but now it's dead on, less than 1/10 MPG different from my hand calculations.
Martinjmpr is offline   Reply With Quote
Old 01-25-2011, 05:53 PM   #10
They do vary a lot as Holycow said.
The one I have in my GM variant is accurate as hand computing and shows down to 0.1 ltr/100 klm.
I had a free (under warranty) upgrade of the electronic unit which makes the actual calculations but it seemed to be just as accurate before as after.
Peter.
GasSavers_Pete is offline   Reply With Quote
Tools you keep in the car? GasSavers_maximilian Experiments, Modifications and DIY 57 10-08-2009 08:41 PM
When filling up today to check my mileage I had an issue. HondaTorneoSiR Experiments, Modifications and DIY 2 06-12-2008 06:28 AM
Congratulations Jared!!! SVOboy General Discussion (Off-Topic) 7 08-13-2006 08:55 PM
