Civic VX - which tires is better to use for MPG - Fuelly Forums
Old 10-11-2009, 06:40 PM   #1
I know that the factory size is 165/70/13 but will 155/80/13 give me better MPG. When I bought my VX it cames with some new tires and I thought they were 175/70/13. Upon inspecting it, I found out that they were 185/70/13. I'm trying to purchase some new tires for it and I was debating between the 165/70/13 and the 155/80/13. Do you guys think I will be fine with some 175/70/13? What is best for MPG (92 civic vx FED Model).
GasSavers_viperguy is offline   Reply With Quote
Old 10-12-2009, 03:23 AM   #2
I would suspect that the 185/70 would do best, if you could find them.
Between the 165/70 and 155/80 it's a toss-up. The 155/80 is a little taller but the 165/70 is a little wider. My research indicates that, counterintuitively, wider is better for fuel economy.
Is your driving more city or more highway?
Old 10-12-2009, 09:35 AM   #3
basjoos's Avatar
By far better than any of these for increasing MPG would be to get a set of 14" wheels and get the 165/65/14 Bridgestone Potenza RE92 tires used on the Insight-I. I installed them on my car and their rolling resistance is well below that of any of the 175/70/13 or 165/70/13 tires that I've had on my car over the years.
aerocivic.com
Old 10-12-2009, 04:35 PM   #4
Actually I have the 185/70 on my car right now. I guess since it's a toss up between the 165 and 155 than I might just go with the 165. I drive 30% city and 70% hwy.
Old 10-12-2009, 04:37 PM   #5
If that's the case than I have always wanted to put my HX rims on. I'll see what's up. Thanks for the info.
Old 10-12-2009, 04:56 PM   #6
Quick question? Could you point me in the direction of the study that says wider is better for fuel economy. Thanks, Jim
2005 Astro 8 passenger van... plain jane...
I am Jim. She is AstroTurf, and yes she is fun to roll around in.
Nokian WR G2 SUV 215/70 16R
Dyna Beads Dynamic Balancing Solution
Aquapel Glass Treatment
Sylvania Xtravision
Pro-Cut PFM On-Car Lathe
astroturf is offline   Reply With Quote
Old 10-12-2009, 05:47 PM   #7
There is a severe lack of good data and complete studies on rolling resistance.
In my sig, there is a link to my thread on tire width where I placed an excessive quantity of my thoughts and research. In short, I can't prove that either narrower or wider is better for fuel economy.
What I do have is an understanding of some underlying principles that don't get much thought in general.
  • At a given pressure and load, contact patch is expected to be the same regardless of width. What changes is its shape; a narrow tire has a longer, narrower contact patch, which requires more sidewall deformation to make that contact patch. Sidewall deformation for making a contact patch is a major component (possibly the largest contributor) of rolling resistance.
    * I believe that I am correct about all that, but I have doubts. Some data shows that modern automotive tubeless tires' contact patches don't adjust quite that way, unlike (for example) bicycle tires.
  • A tire that holds more volume of air has a higher load capacity at a given pressure. Using less of a tire's laod capacity (again, at a specific pressure) means reduced rolling resistance. A wider tire holds more volume of air.
  • One person's study: http://priuschat.com/forums/prius-te...rc-4-data.html
    Originally Posted by that study
    Michelin Tiger Paw AWP P225/60R16 at .00683 - a 25lb tire. On both these model lines, the smaller/lighter/narrower the tire gets, the higher its RRC/4.
Old 10-12-2009, 05:52 PM   #8
There's also these issues, which may be less important:
  • Aerodynamic drag - narrower tire is better.
  • Keeping your momentum around turns - wider tire is better.
Both would have a tiny, immeasurable effect on your fuel economy.
Additional issues:
  • Circumference/diameter - A taller tire will raise your effective gearing, lowering your RPM. Although the sizes in question are nominally similar in diameter, they are a little different.
  • Tread life vs. price - IMO, this is the most important issue to consider. If you save $20 in gas over the life of the tires but have to buy tires more often then you've lost.
  • Pressure - Check the maximum pressure rating of each tire you're considering. I'd rate this as second most important.
Old 10-12-2009, 06:05 PM   #9
the holy cow, Could you give a size comparison to wrap my thoughts around. Thanks, Jim
Sylvania Xtravision
Old 10-12-2009, 06:09 PM   #10
What sizes would I compare?
I really can't quantify the possible gains. It's all theory, there's barely any data out there.
converting a 1 wire o2 to a 4 wire heated o2 ? guest001 General Fuel Topics 3 11-02-2008 04:41 PM
Considering buying a Geo Tracker (and making the first Tracker XFi) CoyoteX General Discussion (Off-Topic) 17 10-31-2007 04:24 PM
