Civic VX - which tires is better to use for MPG - Page 3 - Fuelly Forums
Old 10-16-2009, 07:09 AM   #21
I have Michelin Harmony tires size 175/70R13. They are quiet, smooth, have excellent grip in rain, snow, and dry conditions (outstanding performance in the snow due to open tread blocks on the outside of the tires, one of my prerequisites to buying a tire). After being on the car for nearly 20,000 miles, they show almost ZERO wear.
Old 10-16-2009, 08:53 AM   #22
My bad... they're Michelin Destiny tires, not Michelin Harmony.
I paid $225 or so for them at Discount Tire. I have seen mileage soar into the high 50s to mid 60s with sensible driving with these tires.
Old 10-16-2009, 03:58 PM   #23
Originally Posted by CA ExhaustCoatings View Post
http://www.physicsforums.com/archive.../t-330790.html
so it seams we were both half right.
my conclusion is two tires of the same OD and two different widths will basically have the same contact patch. As I had stated earlier, a larger OD will increase the contact patch. So to have the smallest contact patch a tire would have to be wide with a small OD. But according to the white paper posted and as most know aerodynamics reduces mpg the most at 50 mph and over, whereas wide would be bad.
It seams a balancing act is needed for the use of the vehicle and weather conditions one expects to see for the best mpg size tire to use.
Using a larger dia wheel so that the tire side wall is smaller will help reduce tread movement thereby increasing mpg.
Ah! I must have missed the part about diameter; I had assumed we were talking about the same diameter, where we only change the width.
I totally agree that a balance is the best idea.
As for low-profile tires...Common knowledge has been that upsizing (same OD, larger wheel, smaller sidewall) results in increased RR (and decreased MPG), but I'm not sure that I've seen any data. I think I also haven't seen any logic to explain it in either direction, so I can't really say if one way or the other is better.
Old 10-16-2009, 05:07 PM   #24
Larger wheels almost always reduce mpg even if the total OD of the tires is the same as the old wheel/tire combo. Often it's the city mileage that takes the worst hit because it requires more effort for the engine to get larger wheels moving compared to smaller wheels. There might be some exceptions though where the larger wheels are significantly lighter (eg. made of magnesium) than the older smaller wheels made from a heavier material.
GasSavers_Bobert is offline   Reply With Quote
Old 10-20-2009, 06:03 AM   #25
not true. look at the white paper I posted. Any thing that can reduce tread movement helps mpg. a shorter stiffer sidewall works. Too big and wide of a wheel whereas the unsprung weight goes up too much, then I would agree.
I biggest pet peeve is these hwy depts that groove the hwys, this increases tread movement lowers mpg but increases the states fuel tax revenue as a result.
CA ExhaustCoatings is offline   Reply With Quote
Old 10-20-2009, 02:33 PM   #26
Which highway department grooves a highway? The only grooving I've ever seen was during construction and was temporary (as well as dangerous for motorcycles).
Old 10-20-2009, 02:45 PM   #27
Hoping these will do the same for me. I was lucky enough to get the $70 rebate, so $225 was the net total mounted and balanced. They do look like an awesome tire, especially for the $$$.
I exit lean burn when my life is at risk.
1998 Odyssey 24.1 mpg average
1984 crx project now on the road
hondaguy72 is offline   Reply With Quote
Old 10-21-2009, 06:29 AM   #28
should have been more clear, the rain grooves some hwys have esp calf., u can feel the vehicle moving side to side. I guess some clown thinks because tires have tread grooves that the hwy should also, IMO it just holds the rain on the hwy.
Old 10-21-2009, 01:46 PM   #29
Interesting. Can you find any pictures of it? Here on the other coast, I don't think I've seen anything like that.
Old 10-22-2009, 01:11 PM   #30
THC,
have been to calf. on business trips, I'm south of u in jersey.
converting a 1 wire o2 to a 4 wire heated o2 ? guest001 General Fuel Topics 3 11-02-2008 04:41 PM
Considering buying a Geo Tracker (and making the first Tracker XFi) CoyoteX General Discussion (Off-Topic) 17 10-31-2007 04:24 PM
