Do left turns lower mpg? - Fuelly Forums
Old 06-13-2007, 12:17 PM   #1
GasSavers_jkandell's Avatar
Is it a good rule-of-thumb to eliminate left turns if you can? I'm trying to think of my typical routes, and am not sure whether driving around the block (turning right) would use less gas than waiting and then turning left... What do you all think?
GasSavers_jkandell is offline   Reply With Quote
Old 06-13-2007, 12:22 PM   #2
They do suck! I would try to limit any part of your commute that includes forced stops.
Nice scoot in the avatar, by the way.
Old 06-13-2007, 12:22 PM   #3
If you shut the engine down while waiting for an opening, I'd say that would be most efficient.
Even if you left it running, I doubt you'd save fuel going around the block doing right turns.
Old 06-13-2007, 12:33 PM   #4
Tuggin at the surly bonds
Silveredwings's Avatar
UPS thinks so: http://multichannelmerchant.com/opsa...fuel_conserve/
Old 06-13-2007, 12:57 PM   #5
Moderator
GasSavers_DaX's Avatar
I don't avoid left turns. I judge each turn individually, and as early as possible. If I see a possible opening coming up, I keep the engine running and time the gap. If it looks like I won't be able to make the turn without stopping, I turn the car off as early as possible (enough momentum to get to the stopping point), then either clutch start the car if I'm still rolling by the time I get there or crank the car if I have come to a rest.
Old 06-13-2007, 01:08 PM   #6
ELF
ELF's Avatar
Pretty much exactly what I do.
Old 06-13-2007, 01:35 PM   #7
Alas, this very scoot (an orange Stella) is sitting in my garage damaged after being hit from the rear at a stop light. I'm lucky to be alive, so, my scooter days are over. I'm now riding a Honda Fit--six airbags. In fact, I joinsted this site somewhat from guilt at having to own an auto. I want to at least beat the epa! The stellas are great though--they're modern replicas made in India at a plant that used to make 80s vespas. (Very hypermiler: why pay for a prestigious badge just to be cool?) And they're manuals, so you can coast like crazy.
Old 06-13-2007, 01:38 PM   #8
Originally Posted by Silveredwings View Post
I wonder what the actual formula is, since there is a "break even" point in distance where turning right uses more gas than "idling" while waiting to turn left.
Old 06-13-2007, 01:42 PM   #9
The Stella is made by Buddy? I think I saw one for sale at a forum I'm on the other day.
You should be able to do well with the Fit, I'll be looking forward to seeing your progress!
Old 06-13-2007, 03:14 PM   #10
I think it's a little different for UPS than for someone commuting to work. The UPS drivers make multiple stops, so the software essentially tries to make the route into as much of a circle as possible, and it tries to plan it such that you can make right turns as much as possible.
While it is possible to optimize a route between two locations to use right turns wherever possible, it's a lot less flexible than when you have to make 50 or 100 stops.
I highly doubt the software would tell you to go around a block making three right hand turns instead of a single left, and I would imagine that there are very few situations where that would be more effecient.
Brett
brettds is offline   Reply With Quote
Electronic Radiator Fan Switch holypaulie General Fuel Topics 3 01-27-2007 10:41 AM
