Drifting bad for FE? - Fuelly Forums
Old 02-15-2008, 10:20 AM   #1
I've been thinking about this for awhile now so Im going to try and explain and see what you guys think. I'm not sure exactly how to explain it, so I'll do my best and you follow along . It all comes down to, if you left your car idle for a solid hour, how much fuel would you consume?
Im going to use my Metro as an example. Would it be safe to say that a 1 hour idle burns 1 gallon? If that is so, imagine drifting down an infinitly long hill at a constant 30mph. Even though you are drifting, a very good FE technique, after 1 hours drive you would only net 30mpg. Thats horrible for my car.
So, in theory, to get up to my average 60mpg in the summer months, you have 2 options. Either the 1gallon per hour estimate is clearly incorrect and it is closer to 1/2gallon per hour (thats alittle hard to believe), or you would need to increase your speed to net a higher mpg. So, at some point, accelerating would be more effecient than drifting.
Of course, that makes sense. To take it to the extreme, if you only drifted at 1mph, you would only go a few miles on an entire tank. At 15mph, you would increase FE by going further before your tank ran out. So, where is this "sweet spot" on the entire spectrum where drifting is not hindering your FE but excessive accelerating is not hindering you either?
Got that? I know there are tons of veriables, but work with me here . My car is a `95 1L 5speed btw...
Nic
Old 02-15-2008, 11:06 AM   #2
GasSavers_Red's Avatar
I don't think your Geo consumes nearly that much at idle. To put it in perspective my Jeep's 4.0L I6 consumes 0.6 gallons per hour @ idle. Your Metro has to be much much lower than that.
Old 02-15-2008, 11:50 AM   #3
bones33's Avatar
Our 6cyl 250hp Honda Odyssey uses .4gph at idle. If your Geo uses half that (not unreasonable) in the scenario you provided, that would would put your 30mph coast at 150 mpg which is probably not too far off.
Also the term 'drift' is usually used for tire smokin' sideways drivin' fun. Usually done with a rear wheel drive car with lots of full throttle use. Please 'coast' or 'glide' instead so you don't get misunderstood.
Old 02-15-2008, 11:52 AM   #4
"Drifting" has the connotation of driving sideways with rear drive wheels spinning and front brakes applied. <beatr beat me!>
If 'coasting' is a better description, then there are two versions:
Coasting in gear, engine at faster than idle speed, or
Coasting in neutral, engine at idle.
In neutral (clutch pedal down or lever out of gear) means the engine is using some fuel to maintain its minimum rotation speed.
Coasting in gear means the car is driving the engine faster than the idle speed. Most electronic fuel injected engines completely shut off the fuel under these conditions and resume the idle fuel volume when the rpm drops that far. But this is engine braking and reduces the distance that can be covered while coasting.
To completely oversimplify:
Coast in gear, foot off the accelerator, if the hill is steep enough that you'd need brakes to prevent going faster than you'd like.
Coast in neutral, foot off the accelerator, if you'd otherwise need some amount of gas to keep from ending up going slower than you'd like.
Old 02-15-2008, 12:36 PM   #5
palemelanesian's Avatar
My 1.6L civic used 0.2 or 0.3 gph idling. Your metro should be lower than that.
Idling while moving = awesome mpg!
15 miles per hour / .3 gallons per hour = 50 mpg. Any faster than that and you're golden!
Old 02-15-2008, 04:56 PM   #6
You're either talking about drafting or gliding (EOC), drifting is a stunt driving maneuver and is done with complete disregard towards fuel economy (or anything else for that matter, drifting in the sense of the word is absolutely not economical).
Old 02-16-2008, 05:02 AM   #7
DarbyWalters's Avatar
Man, I would love to find that 1 hour downhill!!!
Old 02-16-2008, 06:07 AM   #8
Or you could use the most efficient method ever... and just coast with your engine off. Nothing beats no fuel use whatsoever (ok, you do have to restart the car at some point).
Old 02-17-2008, 07:31 AM   #9
Snax's Avatar
It's the return trip that sucks!
Oh, and drifting is great for fueling the economy. If you own stock in an oil company that is. :P
LiberalImage.com
I think, therefore I doubt.
Old 02-17-2008, 06:40 PM   #10
Thanks for the information guys! I never expected my fuel consumption at idle to be so low. It sounds like my gph is closer to .2-.3. That makes a world of difference in calculations.
LOL, you guys beating me for using the term "drift". Can you imagine a metro "drifting"??? I've always used that term, but I'll keep that in mind now that the japanese culture has overthrown our own...
Yes, EOC'ing is where I make alot of FE gains. Currently though, with this freezing weather, it has gotten my spirits down and I just get from point A to point B ASAP. Not only mentally, but it physically hurts my FE becuase all my driving is short trips so about 80% of my driving is with a cold engine. I am still averaging 45mpg, but in the summer its easy for me to get in the 60's. My record is 78!
Partial Fuel-up Calculations Improvements ryogajyc Fuelly Web Support and Community News 16 04-17-2012 08:25 AM
Add Groups? ScoutTech Fuelly Web Support and Community News 3 03-17-2010 10:35 PM
Trying out an aftermarket intake GasSavers_TomO Experiments, Modifications and DIY 17 06-01-2007 09:31 AM
$80 civic vx tranny in MN GasSavers_Ryland For Sale 0 05-15-2007 01:32 PM
parting out Honda d15b2 engine Matt Timion For Sale 0 06-27-2006 04:14 PM
