Originally Posted by philmcneal
this is why I like stock... and i need to convert my brake lights to LED -_-
also this is why i never use my accessories... maybe the defrogger once in a while to keep the A/C lubed up.
I see you're in BC... When I see people saying how easy it is not to use the A/C, invariably they aren't in SE Texas.... Here if you don't use your AC, then you show up to work drenched in sweat. It isn't merely comfort, it's a requirement unless you work at a gym where being drenched is OK. Going without AC in a Texas Summer is like going without heat in a North Dakota Winter - nearly suicidal.
As far as the electrical loads... I believe that the biggest loads are two things, lights and fans(AC/Heat). Lights you cannot avoid, as you'd be blind at night without them! AC/Heat, you can avoid
climate permitting. Heavilly amped stereo systems may very well put a huge load as has been pointed out too, but honestly, I don't see how anyone needs thousands of watts. I like a little more than stock, but that's it.
