FE driving, good for mpg but bad for emissions? - Page 2 - Fuelly Forums
Old 05-15-2007, 07:04 AM   #11
With advances in battery tech, electrically preheating the cat may become an option in future hybrids.
Then again, advances in batt tech mean we'll be using the ICE less and less anyway as the proportion of electric propulsion increases vs ICE propulsion.
Old 05-15-2007, 08:42 AM   #12
omgwtfbyobbq's Avatar
Welp, based on FireEngineer's statement, and this paper, I'm pretty sure the Camry hybrid's glide window is smaller because of emissions. If y'all check Figure 3, you can see that catalyst efficiency drops significantly as a *function of temperature. Now, in terms of a hybrid, the catalyst on a stopped car would definitely not cool as quickly as one on a moving car, so I'm assuming that's anecdotally not a problem, and maybe it isn't much of a problem in warmer climates. But if the catalyst temperature drops below ~250C, efficiency drops rapidly, and when the engine turns on again it must dump another rich excursion through in order to light off the cat again, which I'm guess will significantly increase HC emissions on an SULEV vehicle, which requires ~99.5% HC conversion rate. If that rate drops below ~100% for, say, 5 times on a ten mile trip, instead of the usual once assocaited with startup, it could drop the vehicle down to LEV status. If anyone here is actually concerned about emissions as well as fuel economy, which some posters claim to, I think getting a pyrometer down there to make sure everything doesn't cool off too much would be a good idea.
*This is also why my truck runs so rich from the factory. The richer mixture from the carb required to make sure emissions don't go too lean and kill the cat are good for ~3mpg across the board.
Old 05-15-2007, 09:03 AM   #13
Their are a whole bunch of tradeoffs, here, if you look close enough.
For example, do the emissions you do not emit, while the engine is off, save more than the increased emissions, if any, which are put out when the car is turned back on?
If the engine is at "normal" temperature, which for arguments sake is a minimum temperature where the catalytic converter will function, how long can the engine be turned off, with no air flow through the catalytic converter, since the engine is off, before the catalytic converter gets cool enough to not function.
If you've just climbed a grade, the catalytic converter will be at a significantly higher temperature than the minimum required for it to function. How much engine off coasting, down the other side of the hill, is possible, before the catalytic converter gets to a low enough temperature where it begins to not function properly.
If you really want to monitor this, maybe you could get a remote sense thermometer and put it next to the cat, so that you could monitor how hot the cat gets under normal, level driving, so you could have a baseline to monitor the temperature, so you only coast as long as the cat is hot enough to function when you restart.
If you discover the catalytic converter is getting cool, to easily, maybe you could have a muffler shop build a steel blanket to put around the catalytic converter to keep it from cooling down so fast?
If someone has the way or means to measure or monitor this some way, that would be great. In the meantime, I doubt that anyone doing EOC to cut their fuel costs, should be discouraged in any way from the very positive contributions they are making.
Old 05-15-2007, 09:13 AM   #14
No, not discouraged. But at the same time, depending on outside temps, etc... they shouldn't think that their actions will keep everything hunky dory. The majority of HC emissions happen when the car is started and the cat has to be lit off w/ a colder engine. If I do an EOC, and drop the cat's temp to below ~250C, it has to be lit off again, which means another rich excursion, and another HC spike. The thing is, as long as the cat's operating correctly, HC emissions are virtually nil (Figure 3 last post). If it's required to light off again, that's going to be something more than nil. So, no matter what, if the cat's operating temp drops enough, we're going to see a spike compared to a properly operating cat, because it should allow nearly no HC emissions.
*sigh*
Does anyone read any of my posts? Or do y'all just ignore me?
Old 05-15-2007, 09:14 AM   #15
Nope. I think you may be misinterpreting the Camry glide issue.
The car will go ICE off with no difficulty when the accelerator is released, once warmed up, just like the Prius.
So the Camry's glide "problem" isn't getting the ICE to stop running - it's getting the car to coast while also avoiding either regen or EV assist (which has little to do with cat temps).
Old 05-15-2007, 09:16 AM   #16
zpiloto's Avatar
omgwtfbyobbq when they test the emission on a hybrid how is that test done? Don't they take this into account when they certify it?
Old 05-15-2007, 09:27 AM   #17
It's not about the ICE stopping, it's about how long the driver can travel at some ~speed w/ the engine off and the cat cooling down. If the car's in regen mode, it's going to slow down faster than if it were coasting, vera? And the same goes for EV assist mode except it'll accelerate faster. The whole point imo is that is the driver is accelerating or decelerating at a rate faster than a coast, Toyota is minimizing the amount of time the ICE is off and the cat is cooling. Unlike w/ the Prius, where they disabled the EV button, but drivers were still able to get it to coast for relatively long periods of time, which can cool down the cat more than if over the same period of time the car was decelerating or accelerating more. By doing those two things, exaggerating acceleration and deceleration if you will, the amount of time the ICE is off and the cat is cooling is a relatively certain quantity.
zpiloto, I wouldn't think so. I'm not sure exactly how the emissions test is done, it may be the same as the economy test, but I doubt they have a situation where they P&G from 35-45mph.
Old 05-15-2007, 06:19 PM   #18
Well I would have to agree with the question raised by the original post. There is no doubt that I have abused the EOC thing once I saw what it could do to my mileage. It is also quite apparent to me that my car is still in a rich mode at the end of many of my burns in the morning . Often the engine runs less that 1/3 of the time and the burns are about 10 seconds long.
Hypermiling is new to me and I am still amazed at how far I can move my car on a small amount of gas .
I know I have to be polluting more. I was just trying to not think about it. The pyrometer is a very valid idea. Maybe an asbestos wrap or something like that is in order.
Maybe there is an inexpensive analyzer that could tell us when the cat is burning. My nose can certainly smell unburned hydrocarbons but if I ran a hose to the tailpipe it might look like I was trying to do something much worse than get better mileage .
usedgeo
Old 05-16-2007, 06:08 AM   #19
It would be nice to know how quickly the cat cools down. I dont know where you could get a sensor that would measure those kind of temps.
I think directing more airflow above the car, and waiting several minutes after COOLANT reaches operating temp would be safer for emissions. I don't EOC in the wintertime, because it is so cold out (N. Vermont). I only do it when temps are over 50 deg F...kind of similar to my dads hybrid civic's autostop...except i am more careful, because i know the cat cools off faster when the car is moving.
It would be nice to have a metal fairing around the cat to deflect airflow...that you could remove during the summer.
Like everything it is a balencing act...there are sometimes unforseen consequences from trying something different. I think in cities emissions (hc, nox, so2, co) are more of an issue because they affect people directly and sometimes severely due to the density of traffic. In the countryside, co2 might be a more major concern (though emissions still have a negative effect in the country: nox and so2 cause acid rain). in the countryside it would make more sense to run a diesel vehicle or other carbon efficient engine with higher emissions...or maybe to EOC a bit more than in town.
GasSavers_James is offline   Reply With Quote
Old 05-16-2007, 06:52 AM   #20
zpiloto's Avatar
Here's some interesting info on CATs I don't know when you would EOC with the engine is not at idle but:
It is worth noting that switching the vehicle's engine off at anything above idle speed can be very bad for the catalytic converter. In this instance, unburned fuel will enter the catalytic converter and very likely ignite on the element (the heat shield that surrounds a "cat" is there for a reason), damaging the converter and making it perish faster.
Running the engine when it is misfiring, tow or bump starting the vehicle, or running it with an over-rich air/fuel mixture will have the same effect - allowing unburned fuel to enter the catalytic converter and possibly ignite.
Moreover, running the car if it is (visibly) burning oil, or using leaded fuel will coating the element in the catalytic converter and clog its passages, reducing its converting efficiency and possibly causing an overheat.
And more interesting reading.http://vehicle.me.berkeley.edu/Publi...eti_Avec06.pdf
Adding a Fuel up Correctly skim518 Fuelly Web Support and Community News 2 10-22-2012 06:16 AM
Car was with mechanic - let idle for a while - how to handle? 5mall5nail5 Fuelly Web Support and Community News 15 02-16-2012 06:47 AM
2006 Georgia Tech Auto Show Review w/ Pictures GasSavers_DaX General Discussion (Off-Topic) 10 04-06-2006 06:54 AM
