MID/VSS issue - Fuelly Forums
Old 05-12-2006, 04:18 PM   #1
MID/VSS issue
So I'm trying to hook up something electronic that runs off the VSS. My friend has done so successfully on his Del Sol, but I can't get the VSS portion to work.
What I'm wondering is if this needs to have an electronic signal, where can I get that signal in my 91 CRX? I am told it gets converted to digital somewhere, but I dunno where.
I have an OBD1 ecu swap if that matters.
Thanks.
Damn h-t post right there. Anyone here got any ideas?
Old 05-12-2006, 06:19 PM   #2
Moderator
GasSavers_DaX's Avatar
I think it gets converted to
I think it gets converted to an electrical signal at the back of the speedometer, but I have never found exactly where this is. I have taken apart many gauge clusters and I do know that cable VSS's clusters have electronic connections at the back of the gauge, but I don't know which wire to tell you to use.
This is something I need to think about before I do an OBD-1 conversion, because the OBD-1 ECU's need a VSS signal.
Old 05-14-2006, 10:40 AM   #3
Theres only two wires. It does get converted at the back of the speedo, or in some cases you will just have to follow the mechanical cable to the VSS drum.
You can find out which wire by just using the voltmeter while the motor is running, and a sprinkle of common sense and patience Experimentation is needed in just about every case.
I hook up navigational systems and run into this problem.
-unknown
Old 05-14-2006, 10:48 AM   #4
I think I am needed the
I think I am needed the electronic model, which happens to be broken on the transmission I got,
Old 05-14-2006, 05:16 PM   #5
wish I knew more to help, I just always thought they were same...I didn't think the conversion whether made in the tranny or behind the speedo would give any different a signal. On my 89 Chevy, the vss signal goes right into the ECU. And it gets converted where the maechanical line ends behind the Speedo...
I just figure if your car has a speedo that works, then you have a signal you can splice into and use. :?
-unknown
Old 05-14-2006, 05:18 PM   #6
That's what I had though,
That's what I had though, I'll have to test it, I guess.
****ing **** is all I can say.
Old 05-14-2006, 05:30 PM   #7
cool yah just give it a whirl
-unknown
Old 05-14-2006, 05:33 PM   #8
I'm just a little clueless
I'm just a little clueless why it wouldn't work on the wire going to the ecu, and it doesn't look like I can shove this electronic vss in my auto tranny, I guess I just need to get the swap over with, though that's very scary.
Old 05-14-2006, 08:02 PM   #9
"wire?"
Mine has two, a purple and a yellow lead.
-unknown
Old 05-14-2006, 08:22 PM   #10
Mine has a big piece of ****
Mine has a big piece of **** centimeter thick cable to the cluster, then one wire going to the ecu. The electronic one has three wires, 5v, ground, and wire to the cluster/ecu.
iphone mobile broken RicksCafe Fuelly Web Support and Community News 2 01-22-2012 06:02 AM
UK MPG/US Gallons bl4desman Fuelly Web Support and Community News 3 07-14-2011 06:08 AM
Joint Membership with GasBuddy? Badams Fuelly Web Support and Community News 2 07-01-2011 11:14 PM
Average MPG graphs misleading jostlehim Fuelly Web Support and Community News 9 04-16-2011 12:35 AM
Kilometers per liter (KMPL) petrolgeek Fuelly Web Support and Community News 9 05-19-2010 06:35 AM
