Need Help plz! HF tranny codes - Fuelly Forums
Old 09-12-2008, 03:13 PM   #1
Member
78si's Avatar
I recently bought a "HF" tranny from Montana. I did the internet gear check and it came up as a DX.
I'm trying to figure out the L3...... codes
If you have a HF tranny can you PLEASE post your L3 code on the gold sticker. Or if there is any other way of identifying the HF tranny. I need something concrete to show the wrecking yard that its not an HF tranny.
Thanks !
78si is offline   Reply With Quote
Old 09-12-2008, 03:59 PM   #2
Member
From what I'd read on some other forums back when I was researching them, the code on the gold sticker was some sort of serial number and didn't reflect the gear ratios. I don't know that for a fact however. In any case, my 1988 hf 49 state transmission has a code of L3-1121866. Good luck.
nowhhs is offline   Reply With Quote
Old 09-13-2008, 10:08 AM   #3
Member
78si's Avatar
Thanks! I dont think that the gold L3 sticker tells us much, but I would like to know what the numbers mean.
http://www.honda-tech.com/zerothread?id=1551508
http://www.sohchonda.com/forums/inde...53&#entry99053
I did find some info:
look above the oil fill, there is a stamp that will say PL3/####
PL3/A### = small bearing case - DX/HF/STD
PL3/B000 = large bearing - SI/ZC
PL3/3000/6000/9000 = large bearing - SI/ZC
Old 09-13-2008, 10:33 PM   #4
Loserkidwac's Avatar
Send a message via AIM to Loserkidwac
MPG Noob
03 Mazdaspeed Protege
91 Honda CRX Si
95 Honda Civic VX *RIP 5/20/08
94 Honda Del Slow D15z1 Swapped
Loserkidwac is offline   Reply With Quote
Old 09-14-2008, 11:34 AM   #5
Member
78si's Avatar
Originally Posted by Loserkidwac View Post
I found that link already. See original post. I need something non-internet based. Info from Honda would hold up in court! haha
Old 09-14-2008, 06:36 PM   #6
That info was put together with help from "Mista Bone" who is the guru of honda trans...His knowledge is probably the best you will be able to get...send him a message on Honda-Tech...
Unfortunately Honda never released any info that I could find that made IDing the cable trans easy
Edit: Ah i never clicked on the link you posted to see you found that picture already...
MPG Noob
91 Honda CRX Si
Old 03-31-2009, 09:00 PM   #7
Quickest and most sure-fire way I've found with the tranny off the car is to just pull the one case side off and count the gears yourself........sounds hard but its only 12-12mm bolts, a tranny plug that fits a 3/8ths ratchet and 2 skinny screwdrivers and its off! Takes less than 5 min to get it off, there are links with pics but at the moment I don't have them
krash133 is offline   Reply With Quote
Old 04-01-2009, 09:12 PM   #8
what's funny is that this method shown in the diagram (and I'll admit that it is valid for the 3 transmissions shown) does NOT account for the two different HF transmissions. People, are we forgetting that there were two different HF transmissions.....that is, 2 different gearings for the HF! There was the Federal models (which is the tallest geared CRX), and then there was the CA model (whose gearing was significantly shorter). Perhaps this fellow/guy bought himself a CA model HF transmission. Everyone always posts (HF trans wanted; although the differences are unbeknownst to them).
GAS GSLR
How do I view graphs on my page? flyingdutchman Fuelly Web Support and Community News 2 08-04-2011 11:54 PM
Free flow exhaust GasSavers_Kraig General Fuel Topics 9 08-07-2006 07:53 AM
I'm seeing stars Matt Timion Fuelly Web Support and Community News 4 05-19-2006 01:54 AM
VX -- Del Sol engine swap GasSavers_moses General Fuel Topics 28 01-06-2006 03:38 PM
