New to the forum..92 Protege DX - Fuelly Forums
Old 04-24-2007, 08:25 AM   #1
Just wanted to let you know about my beater car that gets me good gas mileage, and ask a few questions.
My car gets 41.96 MPG when driven carefully under 80% highway 20% stop and go.
Believe it or not, those numbers were with 2 quarts of lucas stabilizer and 2 quarts of Valvoline High Mileage oil.
The car burns oil at startup, so I suspect valve stem seals, but I dont have the time or money to fix it.
I have recently switched over to Castrol 10w 30 High Mileage oil and it seems to smoke the same or less now.
The air conditioning compressor locked up on me, so I can't use it
I am probably going to pop a new one up there because driving down the highway with my windows open is killing my gas mileage, but with 100 + degree summers, and close to 100% humidity, I can't get around it since I am forced to wear businesss casual.
I feel blessed that this forum does exist.
Any thoughts on my car and getting better gas mileage? FYI it is the 1.8 SOHC in this car.
Thanks
92 Protege DX 5 speed - Poor Man's Hybrid 40.96 MPG (city)
Thicker 2 row radiator, walmart hubcaps, Pepboys tires, 10w 30 Castrol HM, Jensen CD player, Roadmaster speakers, ebay hi-flow air filter, autolite 3924 plugs, stant superstat, NGK blue 8mm wires, LeBra car bra, no Exhaust Manifold heat shield, MX-3 Seats, bad A/C compressor
jj94auto is offline   Reply With Quote
Old 04-24-2007, 09:06 AM   #2
Welcome to GS
Hi -- Welcome to GasSavers
Tell us a little bit more about your Protege...is it the 5-speed, how many miles?
Also, what part of the world are you in? -- an approximate area is OK. (Sounds uncomfortable without the A/C).
I understand with the air, though -- windows down on the highway is bad aero, but the compressor uses up the fuel -- and business casual isn't very good soaked. Problem is, you'll probably see a decrease in economy if you replace the compressor, since it will probably be used in City driving.
But, there are ways to improve beyond your baseline, even with the A/C...
For basics, I recommend the stickies in the General Discussion forum to get started.
There's also a "Gas Mileage Contest" going on that has a good thread about some advanced technique and lessons learned.
If you have any questions, we're always here to help
Best FE,
RH77
Old 04-24-2007, 09:07 AM   #3
My wife had a '91 Protege. What a nice little sedan it was...
You are doing well with the mileage, it seems. Poke around here some and you will find some ways to do even better.
Old 04-24-2007, 10:31 AM   #4
Thanks all. I thought I posted that I was in the DC area. Whoops!
It is the 5 spd.
I am pretty crafty with mechanics and since gas has gotten more expensive over the years, I have learned to stop seeing how quickly I can go down the quarter mile and do something for my wallet.
Thanks for all the tips.
Can't change vehicle pic?! lauriejennifer Fuelly Web Support and Community News 2 04-28-2010 11:05 PM
Problems with the Recently filled up section VWJunky Fuelly Web Support and Community News 2 03-19-2009 03:13 AM
To he!! with diesel... Brian D. General Fuel Topics 11 10-30-2006 07:36 PM
Poll: Should Stability Control be Standard rh77 General Fuel Topics 14 09-30-2006 09:44 PM
5 different Metros for Sale-Perkasie, Pa / cams XFi For Sale 11 08-26-2006 04:17 AM
