Tune up Time for the Vibe - Fuelly Forums
Old 07-15-2012, 02:46 PM   #1
goofy1's Avatar
Our Vibe is up for a tune-up. It's a 2006 Vibe 1.8L VVt-I. Any suggestion for plugs, wires, etc?? This is our main car for work, trips...etc. Thanks
Matt
"But Doc, we dont' have enough road to get it up to 88 miles per hour"
goofy1 is offline   Reply With Quote
Old 07-15-2012, 05:39 PM   #2
Re: Tune up Time for the Vibe
like your prizm, dont think you have wires, likely coil packs that shouldnt need replacing yet....as for plugs, iridiums are likely recommended for that vehicle.
advance auto parts has coupon codes that will take the sting out of those expensive plugs btw!
Old 07-16-2012, 08:36 AM   #3
goofy1's Avatar
thanks Bowtieguy. Any other recommentations?
Old 07-16-2012, 11:03 AM   #4
just the usual...check: air pressure in tires, air filter, tranny fluid, brake fluid, serpentine belt, and coolant and hoses. change motor oil(synthetic) to a 0W30 viscosity w/ filter of course. put in a quality fuel system cleaner or make your own. clean the throttle body.
Old 07-16-2012, 01:09 PM   #5
tradosaurus's Avatar
Matt
How do you know it is up for a tune up?
tradosaurus is offline   Reply With Quote
Old 07-18-2012, 10:50 AM   #6
goofy1's Avatar
According to Vibe forums and the manual. 100,000 miles when it's suggested to do a tune-up. But most of the Vibe forums talk about tune-ups to increase performance. I dont care about that. I want, of course, better mpg, but also parts and stuff that will help keep this car going strong way beyond 200,000 miles. I know it needs a new belt, a rad. flush. The brake fluid is just a hair below full. Do you think a brake flush would be good?
Old 07-18-2012, 10:55 AM   #7
goofy1's Avatar
oops ..the transmission fluid was flushed last year. I've never cleaned the throttle body, is it hard? I'm no mechanic, and i dont have much experience in doing repairs. :-(
Old 07-18-2012, 12:06 PM   #8
If your car is at 100,000 miles then:
1) New Spark plugs
2) New Spark plug wires or coil on plugs
3) New radiator hoses
4) new timing belt (if not done yet)
5) brake fluid flush
6) Change out power steering fluid (use giant syringe and take out as much as you can and replace)
7) New serpentine belt or drive belts (if never replaced)
8) New fuel filter
9) Check brake pads/rotors
Old 07-18-2012, 06:38 PM   #9
i wouldnt replace the coils unless absolutely necessary...very expensive
the car likely has a timing chain
the fuel filter is likely in the tank
clean the throttle body by pulling off the air intake tube and/or air filter housing. then spray cleaner in the throttle body while scrubbing w/ a tooth brush.
Old 07-23-2012, 08:08 AM   #10
goofy1's Avatar
I'm thinking about getting an K&N filter. Not so much for more power/mpg but more of that i don't have to keep replacing the air filters. Do you all think they're worth $$.
Engine size?! DuckFeet Fuelly Web Support and Community News 1 04-25-2012 09:58 PM
Help...MPG calculator not working djquik1 Fuelly Web Support and Community News 1 10-18-2010 04:57 AM
eBay: 1982 Ford pickup Electravan MetroMPG Electric and Solar powered 2 06-24-2007 06:34 PM
Diesels are very efficent at idle? philmcneal Diesels 36 04-05-2007 06:25 PM
