95metro about to conduct ambitious (blind & controlled) acetone test - cancelled - Fuelly Forums
Old 10-11-2006, 10:19 AM   #1
Documented on his web site:
http://www3.telus.net/metro/tests/acetone.htm
The only comment I suggested to him was to use a looping test route, rather than driving in only one direction on a sample (and back again for the next).
A looping, or bi-directional route will average out wind/grade effects. I'd be more skeptical of comparisons made between samples going in one direction against those going in the opposite direction.
Old 10-11-2006, 10:34 AM   #2
zpiloto's Avatar
I agree. It sounds like it will be a great test. I guess we need to see if he will let us add that to the busted or confirmed list. Any wagers on results?
Old 10-11-2006, 10:41 AM   #3
I'm wagering about a 5% variability between all the samples (including the controls), so NO evidence that acetone (or the other additives) is better or worse than the others.
You?
Old 10-11-2006, 12:01 PM   #4
zpiloto's Avatar
You?
I'm going to say no positive results also maybe even a slight decrease. His metro is already efficient. It seemed that those with FE measuring equipment saw no increase with the magical juice when tested.
Old 10-11-2006, 03:38 PM   #5
It will make more improvement if he goes slow with light throttle.
Old 10-12-2006, 07:15 AM   #6
Mark cancelled the test. Running the car out of gas proved problematic, and inconsistent:
I had many kilometers of low-no power driving. It kept going by feathering the throttle, but if I asked for more it started to fade. I was worried about the fuel pump over-running and eventually destroying itself - especially after 12+ run-dry experiments. Plus, the car kept restarting every time it supposedly ran out and ran down once again.
Too bad, but still gets an "A" for ambition.
Old 10-12-2006, 07:27 AM   #7
Marks too kool. Too bad it didn't work out.
Old 10-12-2006, 10:06 AM   #8
You guys need to setup a 1 gallon jug for a fuel tank and run that inside the car with a valve to switch on the gas tank again. The issue is of course the fuel pump DUH!! which is in the tank so a pressurized tank or second pump is needed or some precise fuel metering gauge. The other problem is the fuel pressure regulator recirculates the over flow fuel back into the gas tank on some cars like the Geo - apparently not my xB.
Old 11-11-2006, 11:13 AM   #9
GasSavers_lane's Avatar
huh?
did he put WATER in his fuel tank???
GasSavers_lane is offline   Reply With Quote
Old 11-13-2006, 07:13 AM   #10
Acetone in the gas? I assume this is the ratio often bandied about...~2 fluid oz per 10 gallons? Me? I use the stuff...& I don't see / feel much difference, but then again...not much of anything is not gonna make much difference! LOL !
I think (sometimes!) if we compare molecular weights here, we're not gonna see much mechanism for even the slightest delta! It all disappears (good or bad) in the "noise" of life! My tailpipe appears to be a little "cleaner", though. What means this subjective observation? Hmmm.... -Ted Hart
