DIY floats - Page 4 - Fuelly Forums
Old 06-09-2009, 09:07 AM   #31
Plastic is what everybody here sells, though I could grab Al at Lowes next time I am near. A lot of people take their plastic gutters in during the winter here. My aluminum one on my shed (have a French drain for the house) pulled right off. The ice laughed at the recommended supports. Adding three times as many this time!
co de pen den cy
Function: noun
Date: 1979
Old 06-10-2009, 03:15 AM   #32
jmf
I would think optical would be the easiest. Floats will have to move perfect up and down, to much chance for problems. You could just put a couple optical sensors on the original gauge to detect that float. You would have to clean up the tube so the sensors would "see" through it well. Older copy machines have half a dozen or so in them, so i'm sure you can find them cheap or free.
jmf is offline   Reply With Quote
Old 06-10-2009, 05:20 AM   #33
I already have a clear tube hooked up to a tee fitting off of the tank, so it would be pretty easy. I have a bunch of phototransistors and LEDs, so I'd just attach them to a piece of plywood, probably, pointing through the tube. If the switches don't work well maybe I'll check it out. There's no rush on this. I knwo tanks get black goop at the bottom after a while, but I think it stays low so wouldn't be an issue.
Neat idea about raiding a copy machine. Around here that's rough, but in general it's a cool thought!
co de pen den cy
Function: noun
Date: 1979
Old 06-10-2009, 06:40 AM   #34
You might be surprised. Find a copy machine repair place and ask them if they have junkers you can have. They'll probably gladly give it to you. It was REALLY hard to get the people that replaced our to take the old one. It stayed here for months because they didn't want it in their inventory.
Those copy machines usually have sweet steppers in them too.
I got one of those junkers and it wasn't fancy or anything but I'm sure I got about 6 of those photo interrupters from it. They use them mostly to tell where the paper is. If you get one that has the large loading tray system at the bottom it'll probably be good for about 8-10 of them and about 6-8 stepper motors.
- Kyle
Old 06-10-2009, 07:38 AM   #35
...then, in addition to the electronics, you'll have a nice pane of glass, some nice sheets of plastic and metal for future fabrication projects, and maybe enough weight in metal to be worth taking to the scrapyard.
Old 06-10-2009, 07:54 AM   #36
Yeah, I'd purchased a dozen ULN2003 chips for my CNC projects and it turned out that the machine I got had those same chips for stepper driving. Just my luck!
- Kyle
Old 06-11-2009, 04:54 PM   #37
Well, the switches I have are a lot stiffer than I thought. I'd need a big float or a long lever to trigger them.
The optical idea is seeming simpler all the time. Great excuse to learn about phototransistors as well. I wonder what the oil's ability to transmit IR is? That's the type I've got.
co de pen den cy
Function: noun
Date: 1979
Old 06-11-2009, 05:34 PM   #38
What photo transistors did you get? You can modify your floating dowel rod idea but instead of microswitches you can use optics.
I just came up with another idea. You can't trigger store bought micros with floats, but what about home brew? Put a float on a hinge and when the level drops the far side will lower and disconnect. On the way up the force of the oil makes a connection again. I once made a timer switch for a detonator from a dollar store clock like that. I had an 'interesting' youth.
- Kyle
Old 06-11-2009, 06:11 PM   #39
Home brew switches normally make me nervous, but this application is
pretty forgiving: very slow response, no need for consistency in terms of force or triggering position, hysteresis is OK, low number of cycles. Definitely worth considering. Shouldn't be very hard and it doesn't need to even be spring loaded.
My phototransistors are Lite-on LTR-4206s.
How many fingers do you have? I was a wimp: I used to just wire a 1/4 watt resistor into a really, really long extension cord and then plug it in from a safe location.
co de pen den cy
Function: noun
Date: 1979
Old 06-11-2009, 06:24 PM   #40
I have all my fingers, so far. I have been shocked badly enough to lose the use of my right arm though. My handwriting has been horrible ever since. I never used resistors but I did use model rocket ignitors and if I needed a little extra oomph I always had a box of leftover fireworks sitting around to part-out.
- Kyle
How can I get last year's data? sdean7855 Fuelly Web Support and Community News 1 01-20-2010 10:17 PM
Engine Types danb86 Fuelly Web Support and Community News 3 09-11-2009 12:54 PM
prices vs posts here... slurp812 General Fuel Topics 41 12-19-2008 08:23 PM
Sterling Heat pump Steve6f8eh Experiments, Modifications and DIY 4 07-29-2008 12:42 PM
Compression Tester krousdb General Maintenance and Repair 7 07-12-2006 01:59 PM
