07-07-2010, 06:31 AM
Originally Posted by fowljesse
Heheh. I heard of using brownies in the rear diff. No lie.
I would like to decrease the friction in my manual transmission. I don't have any problems, and am going to rebuild it soon, so I'm thinking about possible experiments in the mean time.
If you're going to re-build it soon, go with an AutoRX product prior to doing so instead!
'92 Civic VX, Canadian model
07-07-2010, 08:16 AM
I am curious- why are you going to rebuild the trans if there are no problems with it?
07-08-2010, 05:45 AM
Member
What kind of sawdust is best, hardwood or softwood? And what is the ideal proportion to mix it?
07-08-2010, 06:09 AM
Plus, what size? Chainsaw chips, drill chips, rough circular saw dust, fine dust...
07-08-2010, 07:45 PM
Pine, left over from sawing 2x4s from house framing, is probably best. Mix in some...you'll "know" when you've mixed in enough.
BTW...way back in the before time, I used to use Arco Graphite motor oil. Always worked fine for me, even in my Triumph 650 with a wet clutch. Only problem was that it was really messy when oil would spray onto my good clothes...
07-21-2010, 10:28 PM
Huh. Well, that's what I'm talking about. There must be a reason they don't use it anymore.
The reason I'm rebuilding it is to put in taller gears, and final drive, and an LSD. While it's out I have an aluminum flywheel, and stronger clutch to put in.
07-24-2010, 03:55 PM
I'd imagine if graphite was a beneficial additive it'd already be in one of the higher quality, higher priced, or race-bred and race-targeted brands.
the lack thereof should answer the question. There are some with Molybdenum Disulfide in there, but not much. It's a "little goes a long way" situation.
