Someone has got to do this. - Fuelly Forums
Old 05-31-2007, 03:31 PM   #1
omgwtfbyobbq's Avatar
Thermoelectric generator awesomeness. Now, with a big enough drop in load from aggressive use of LEDs, maybe someone can grab a few of those HT peltiers offa ehay and string together a system that'll provide an average of ~100W all the time for ~$100. When I get the cash this is definitely something I'd go for, since it'll allow me to run my AC comp where the alternator used to be... Increased mileage from no electrical draw, AC, and the same simple belt system. If you do nothing but stop and go, probably not for you, but for those of us who cruise at ~40+mph it could be a nice upgrade.
Old 05-31-2007, 03:39 PM   #2
JanGeo's Avatar
I have to wonder if a couple of HP is going to make a difference in a 300+ hp engine.
Old 05-31-2007, 03:44 PM   #3
I would think so. After all, the trucks not using all 300+ hp all the time, so as an average it's probably something like a .5-1% increase in efficiency. It'd be way higher for passenger cars as Metro has shown, but heavy trucks would be a good test bed since a generator is just one more thing to go wrong, and compared to engine power, the amount of electricity needed isn't too much.
Old 05-31-2007, 04:16 PM   #4
GasSavers_Red's Avatar
Use the cat as a heat source? A new generation of energy producing converters
Old 05-31-2007, 04:40 PM   #5
Precisely, since cat operating temps have to be in excess of 250C, just weld a flat plate on the bottom of the exhaust, or just wrap them around it. So, figure maybe ~60-100C for the cool side, and we have ~150-200C difference, which could give us ~7-12W per module, assuming the $12 ones off of ehay behave like the ones on truck above.
Old 05-31-2007, 04:45 PM   #6
So, would this be using a Peltier TEC in reverse to induce current, or is this another device that is similar?
parasonic is offline   Reply With Quote
Old 05-31-2007, 04:57 PM   #7
Pretty much. A similar Peltier used for cooling is rated at ~85-140W, so I figure the HT series with the same size could put out a tenth of that if used for power generation over the same temperature range.
Old 05-31-2007, 05:10 PM   #8
Tuggin at the surly bonds
Silveredwings's Avatar
see also:
http://www.gassavers.org/showthread.php?p=27687
http://www.gassavers.org/showthread.php?t=2644
Silveredwings is offline   Reply With Quote
Old 05-31-2007, 05:19 PM   #9
oh shiz, can't believe I missed that. DP!
Old 05-31-2007, 05:39 PM   #10
np. It just shows this is a popular idea. In fact, reclaiming the energy lost to heat is probably *the* holy grail of human energy management, especially in cars.
