11-18-2005, 12:00 PM
#1
FE nut
Good fuel Mixture?
Below is a post from betterMPG group on Yahoo. Sounds like my idea to mix acetone and Coleman fuel wasn't too far off. I just may have only overdid it a bit.
According to LaPointe....
"We prefer to add one ounce of Torco GP-7 or Torco EAL into a 16 oz. bottle of
acetone. This improves MPG and the lubricity of the fuel and also improves the
anti-knock rating both to diesel fuel and gasoline. Shake the contents well just
before you add this nice mix to the fuel. The amount remains 2 oz. per ten
gallons in diesels and 2-4 oz. per ten gallons of gasoline.
In gasoline only, we often add Techron right after the acetone. Techron is sold
in most parts stores as a cleaner. We use 2-3 oz. of Techron per 10 gallons of
gas. It is made by Texaco/Chevron."
* As I figure it (not again!)...he uses GP7 at a 0.2 oz per 10 gallon ratio. *
Somebody tried Torco EAL and couldn't get it to dissolve.
I'd use the GP7 with acetone...using the acetone to carry it. Or mix into some
gas?
Since I didn't keep my mpg gains last year with 3 oz acetone...I'm going to go
with the following...
acetone at 1 to 2 oz per 10 gallons
Coleman's at 1 to 3 oz per 10 gallons
GP7 at 0.1 to 0.2 oz per 10 gallons
Using this along with the ozone air bleed thru the distributor.
Also bought a bottle of Techron to test.
Will also try wrapping the O2 sensor with alum foil.
And am making a spiral muffler...
http://www.spiralturbobaffles.com/semiinfo.html
So far...knock on Al Lumininium...I'm holding a a 25 mpg level...with occasional
outruns into the 28-31 mpg area.
Horsepower is how hard you hit the wall, torque is how much of the wall you take with you.
2007 Prius,
Team Slow Burn
11-18-2005, 09:55 PM
#2
Some Advice for Rookies?
The next step for me is to maybe get a fuel blend going. Any advice for rookies to fuel blending? There seems to be a a variety of choices Coleman's, acetone. Any advice?
Thanks...
RH77
11-19-2005, 06:27 AM
#3
*shrug*
My advice would be to jump
My advice would be to jump in there and try it out, and make sure to keep lotsa things constant, because blends testing is a pain in the *** in that way. Start with things that've had lotsa success, I should say, and when you look at comercial stuff, always look at their ingredients.
11-19-2005, 06:53 AM
#4
FE nut
I agree about it being a
I agree about it being a pain. If you end up with a mixture that doesn't help mpg or even makes it worse, you have to just drive it out. That's why you want to keep track of what you're adding real carefully. I will see if I can dig up some more info on fuel mixtures. There is a guy on one of the Yahoo groups that usually has some good info on mixtures. I do remember somewhere that mineral spirits may be a good additive especially for winter because of something about higher volatility or higher btu content.
2007 Prius,
Team Slow Burn
11-19-2005, 06:56 AM
#5
*shrug*
Have you ever tried the old
Have you ever tried the old style mothballs?
11-19-2005, 07:02 AM
#6
FE nut
I've never tried them in the
I've never tried them in the tank. I did try them in an onion bag in my airbox just below the air filter. I had heard that the air with napthalene vapor was more effective than in the gas. My results were inconclusive. I may have to try them in the tank sometime. If you use mothballs, make sure they are the 100% pure napthalene.
2007 Prius,
Team Slow Burn
11-19-2005, 07:07 AM
#7
*shrug*
Yeah, I will. I'm trying to
Yeah, I will. I'm trying to get all of my physical stuff out of the way (water injection, distributor mod, h2, blah blah) out of the way before I do mixing, cuz that seems very fined tuned and I wanna have my setup down pat first.
» Car Talk & Chit Chat |
» Fuelly iOS Apps |
» Fuelly Android Apps |
