Aero aids on an xB. - Page 4 - Fuelly Forums
Old 09-03-2008, 08:46 AM   #31
|V3|2D
thisisntjared's Avatar
it might help if you were to remove that lower section of the rear bump and have your undercarriage pan on an angle up to help reduce the wake behind the vehicle.
would vgs around the tail end of the car help the aerodynamics?
Old 09-10-2008, 08:58 PM   #32
That would look really silly!
The rear aero is a mystery to me, its just flat on top.
Z man is offline   Reply With Quote
Old 09-11-2008, 04:26 AM   #33
|V3|2D
it will reduce 4-5in of wake behind the car...
if anything i would think the vgs might look a little weird looking, but the rear aerodynamics is no mystery, there isnt any.
Old 09-11-2008, 09:00 PM   #34
So does the air shoot straight off the back or spin down or something?
A rear undertray should certainly help, I have the materials, just need the time now.
Old 09-11-2008, 10:55 PM   #35
FormulaTwo's Avatar
Send a message via AIM to FormulaTwo
Good work on the underbody and lip!
Did you ever get around to blocking your grill?
With mine I just used a piece of garden edging, cut to fit and ziptied in place. I will try and get some pictures. (probably took about 5 minutes to do) I wanted something that would be easy to remove, just in case.
Basically, if you WD40 the plastic after you install it it ends up looking really shiny and for me, similar to my stock paint. It really isn't noticable at all, and as long as you use black zip ties noone will notice them either. (I only used one at each corner)
If I were you I would also look into some different wheels. The scion steelies, from what I have read, weigh in around 22lbs. While the Scion Spiral wheels that I have are around 14, and the 7 spokes are said to be about 16 or so. You can find the stock alloy wheels on ebay all day long for $150 for the set. While a lot of people on Scionlife.com and Clubxb.com like to run the steelies with "Beauty rings". Or if there are any "Honda-tuners" in your area, they like steelies for track use. (so it shouldn't be a problem selling them)
I eventually plan to install Enkei RPF1 wheels, which weigh 9lbs each.
I feel like the XB is just a lost hope as far as aerodynamics go and I try to make up for this by never driving over 60mph unless someone else is in the car. (usually on vacations) I was a little more of an overzealous hypermiler whenever I had my "VX Civic".
I really don't expect the XB to get anywhere near 58MPG average and I am completely happy with it getting 38mpg consistently and 42 on those random "good tanks"
Although, I have random thoughts almost daily of ripping the A/C, belts, Alternator, radio out of the car; installing a solar roof and a charger outlet to charge a row of Deep cycle batteries that would be installed in the trunk; lining the underbody with Coroplast and aluminum; removing my mirrors, windshield wipers; blocking off the front bumper completely; removing the spoiler and lining the entire rear of the car with VGs and or Airtabs; removing the carpet, carpet padding and rear seats; gutting the dash; removing the metal bumper supports in the front and rear; and replacing the roof and all windows on the car with plexiglass.
But then I drive the evil thoughts out of my head and realize that everything just might be OK, and if I work hard enough, maybe I can afford a Tesla Roadster one day.
Either way, good work!
Order some golf shoes, otherwise we might never make it out of this place alive.
FormulaTwo is offline   Reply With Quote
Old 09-12-2008, 06:36 AM   #36
|V3|2D
the vgs will help spin the air down into the wake of the vehicle
Old 09-12-2008, 10:51 PM   #37
I see. I wonder what would be good to make them out of?
They wouldn't be too noticeable on top of the 'box.
Old 09-13-2008, 10:25 AM   #38
|V3|2D
plastic im sure it would be easier to just buy a set. unfortunately im drawing a blank as to which thread they were in.
Old 09-14-2008, 11:05 AM   #39
Geesh I've never heard of these things.
Here we go!
Anybody try these?
http://www.manufacturersdepot.com/SP...1180622063.jsp
Old 09-20-2008, 09:35 AM   #40
http://www.gassavers.org/showthread.php?t=6178
http://www.gassavers.org/showthread.php?t=1482
Trying to add a car bw61374 Fuelly Web Support and Community News 1 08-17-2013 07:14 AM
Another mileage contest Sludgy General Fuel Topics 16 11-18-2007 07:39 AM
Factory 2nd Gen CRX passenger mirror delete? UfoTofU Aerodynamics 3 04-02-2007 01:19 PM
I'm going nuts! buying tires soon lovemysan General Fuel Topics 11 12-23-2006 08:13 AM
Search feature added Matt Timion Fuelly Web Support and Community News 1 09-26-2005 02:02 PM
