tigra aero mods - Fuelly Forums
Old 07-18-2007, 06:54 AM   #1
tigra aero mods
now I post my pictures of self aeromods.
First modification include rear underbody with a preliminar extractor with 0,4? degree of inclination, and two cover for the fuel tank.
The used material of extractor, it is the high density polyurethane (bad for the muffler high temperature ) to need to change with fiberglass in next time.
For the tank fuel cover, I've used the polycarbonate about 1,5cm thickness.
this is the pics of under rear car previous modification:
you can see the bad design, the flow of the air, recirculates and blinks against the posterior bridge
this is the scheme of the cover:
now, the pics of job:
the anchorages of rear extractor:
the finished job:
the rear view:
Yesterday, I have constructed front cover and the front deviators like the DRW Job (my mentor http://www.gassavers.org/showthread.php?t=2381 )
For the moment, I have only cut the materials, but this evening I will make the installation
the photos, includes the front engine cover with space for the hot air escape,and preliminary front air deviator for the wheels
the air deviator
excused boys, a question: which name given to the flow shunters?
you have of the councils give give to me?
an example: now, the front cover, is parallel to ground, but most cars, it have this cover with an angled inclination like this
my English is bad, but I do not surrender!
fabrio is offline   Reply With Quote
Old 07-18-2007, 07:44 AM   #2
On the rear, you may want to consider using a more flexible material and tucking it inside the rear bumper to give more complete coverage and smoother air flow under the rear.
Old 07-18-2007, 09:24 AM   #3
bones33's Avatar
Thanks for the writeup! It seems that this aero mod is one of the most common recommendations aside from a grille block. Keep going with the installation and good documentation on what you're doing, and of course the results you find. The more examples we see the better we all will get at doing this in the future.
Don't worry about your english, you're doing fine. Anyone who actively learns another language is better than most. Keep up the good work.
Old 07-19-2007, 01:48 AM   #4
I have thought to extend the posterior cover like you councils, and to create of the vertical fins in order to careen the inner part of the wheels in order to diminish the turbulence, but I do not understand why me councils to use of the more flexible material
Old 07-19-2007, 01:56 AM   #5
thanks beatr, I know that it is important to make good articles for the good of the community like I have already said several times, follows this forum from much time, here why I have the clear ideas on where and like modifying .
often, use the translator in order to write, but I try to use it less possible or at least in order to find the errors rougher.
But, if you want to correct to me, I will be happy of your councils and I will not take offense myself
Old 07-19-2007, 02:17 AM   #6
I am newly here with the news photos
in the first place, I wish that you see the front of original car:
now, this is the frontal car with added Sx engine cover and air deviator.
the profile sight
and the source of materials
the front deviators, needs, of being painted of black colour.
ciao
fabrio
Old 07-19-2007, 05:22 AM   #7
I was advising the use of a more flexible material so that you could bend it to a shape that fits everything smoothly. It appeared to me that the original material was thick and stiff.
Very nice front deflectors.
Old 07-19-2007, 06:00 AM   #8
thanks for your explanation, Bill
the rear extractor is temporary, that definitive, must be in fiberglass, more wide and to also cover the noise suppressor
thanks many for compliment
Old 07-19-2007, 02:19 PM   #9
upgrade semi-ended.
today, I have ended (if one may use the expression)!
the total view:
after an rapid painted
in detail:
tomorrow I go with the tests, hat they are various from yours
Old 07-19-2007, 04:45 PM   #10
Amico, take them OFF the car BEFORE you paint them! :-)
Trying to add a car bw61374 Fuelly Web Support and Community News 1 08-17-2013 07:14 AM
"Partial fillup" on Fuelly Mobile nonfunctional ZiggyTheHamster Fuelly Web Support and Community News 1 05-24-2012 01:03 PM
SMS banner. DTMAce Fuelly Web Support and Community News 3 03-08-2010 09:56 PM
elg's Project zpiloto General Fuel Topics 2 03-03-2007 06:47 PM
If you're jealous of Matt, (or have 56k) don't look here. bagpipe goatee General Discussion (Off-Topic) 8 11-15-2005 06:24 PM
