Graph problems again! - Fuelly Forums
Old 10-24-2011, 05:28 AM   #2
pb
ok, I think I found a way to address this going forward. From now on you can change the order of fuel-ups on the graph by giving fuel-ups on the same day a different fuel-up time. Normally when you add two fuel-ups on the same day the time is recorded as exactly the same. (Or, more precisely, the time isn't considered important.) If you go in and edit a fuel-up you have the option to set a time as well. If you set a later time for one of your same day fuel-ups, it will appear in the correct order on the graph.
I went ahead and set the time of your 2nd fuel-up on Oct 23rd '12:00 PM'. (You can change to to the correct time if you recorded it/remember it.) That should make your graph line up the way you want it too. It's an extra step for same-day fuel-ups but it will help make everything more accurate if you want to do it.
