MPG calculation - Fuelly Forums
Old 09-10-2016, 07:13 AM   #5
RobertV's Avatar
All those entries highlighted in pink are currently being ignored from your calculations.
If you view them, they are being ignored because they have an odometer value of "0". Which doesn't allow for your MPG to be calculated.
The previous version of GasCubby allowed for no-odometer/0 values (I'm not sure why, actually). In an attempt to preserve your data and not remove anything, we migrated everything over, but needed a way to notify you (and others) of obvious bad-data. Simply edit those fuel ups, adding the necessary data requirements (in this case, an odometer value) and save, and it'll no longer be ignored.
The little "i" next to some entries designates "info" that you can mouse-over to view the message. This is used to indicate "This MPG value includes the preceding partial fuelups".
