MPG not being calculated... - Fuelly Forums
Old 12-12-2014, 02:07 PM   #1
Not sure what is going on, but the last two fill ups it did not average my MPG.
noeltykay is offline   Reply With Quote
Old 12-12-2014, 02:23 PM   #2
make sure you didn't mark a fill up a partial.
Old 12-12-2014, 07:13 PM   #3
RobertV's Avatar
I show the last 2 (Oct 24 and Nov 26) calculating MPG...
Old 12-15-2014, 08:07 PM   #4
I have been using Gas Cubby since June 2008 and it has always kept track of my MPG. It stopped calculating MPG in November and as of my last fill-up on 12/12/2014, it still does not calculate MPG. What happened?
wittesr is offline   Reply With Quote
Old 12-15-2014, 11:24 PM   #5
RobertV's Avatar
Can you export a CSV and either post or send to me?
http://www.fuelly.com/gascubby/suppo.../gcexport.html
Old 12-19-2014, 08:26 PM   #6
Same here !
M4dr01D is offline   Reply With Quote
Old 12-19-2014, 09:36 PM   #7
RobertV's Avatar
Originally Posted by M4dr01D View Post
Same here !
Can you provide me a copy of your CSV? Need a little more info to go on to assist.
Old 12-20-2014, 07:00 AM   #8
Change the file extension to .csv
Please add .csv to the file extensions that we can upload.
Old 12-20-2014, 09:21 AM   #9
RobertV's Avatar
Thanks.
The 3 of the last 5 fill-ups were marked as Partials.
Partial fill-ups will not calculate MPG.
Prior to that you have all but one marked as partial back until August 2nd.
If these were marked in error, simply edit and remove the Partial fill-up marker and your MPG should calculate immediately.
Thanks!
Edit-
I also didn't realize you had already moved your data to Fuelly, and you can easily see the fillups that were marked as partials here: http://www.fuelly.com/car/toyota/4ru...01D/298987/log
Old 12-20-2014, 12:51 PM   #10
So, there is no point of indicating a partial fuel-up....weird!
