airflow - is more or less better? - Fuelly Forums
Old 09-28-2005, 01:56 PM   #1
Matt Timion's Avatar
I've been thinking about this for a while now. I guess this goes along with the question of Horsepower and fuel economy that I raised not too long ago.
So, back to the question.
Is it better to give MORE air to your engine, or less air? Some people say that adding a good exhaust manifold and a wide exhaust pipe will give them better mpg (one guy claims a 50 miles-per-tank increase).
but if this is the case, why do all economy builds (I can only think of Hondas right now - the HF, VX, CX, etc.) have smaller than normal intake manifolds? Am I really to believe that Honda's engineers got it wrong when they build their engines? Should they have put massive intakes instead of tiny ones on these engines?
I'm totally baffled by it. Everyone keeps saying "more air, more air" to increase MPG. All that I can see from that though is more power.
So, tell me why I'm wrong, or tell me why i'm right.
Old 09-28-2005, 06:23 PM   #2
Yo
<a href=http://community.foe.co.uk/cgi-bin/yabb/YaBB.pl/YaBB.pl?board=online_actions;action=display;num=10 60791111 target=_blank>Exhaust something</a>
This is not really about exhaust size, but reducing back pressuring (same thing bigger size does) to increase mpg.
Old 09-29-2005, 06:03 PM   #3
It isn't more air that is
It isn't more air that is increasing fuel economy, it is reducing pumping losses through restrictive exhaust/ intake points.
abeja is offline   Reply With Quote
Old 09-29-2005, 06:09 PM   #4
Re: It isn't more air that is
So then there would not be much difference between a 5 inch and 2 inch exhaust on my 92 mpg b2, since a 2 inch cat back is sufficient to reduce back pressure? And could you recommend some cheaper headers/exhaust crap that will still serve the purpose of reducing back pressure even if they aren't super race quality?
Old 09-29-2005, 09:12 PM   #5
kickflipjr's Avatar
Fro mpg the best setup would
Fro mpg the best setup would have the best wind speed velocity. Big exaust pipes slow down air velocity. It's too bad they dodn't make performance intakes in 1 3/4" or 2" size. that would be better then the standard 3"
2008 EPA adjusted:
Old 09-30-2005, 08:00 AM   #6
Re: Fro mpg the best setup would
Is there some way to figure out hp versus exhaust size versus speed to figure out what be would optimum?
Old 09-30-2005, 08:23 AM   #7
kickflipjr's Avatar
One side affect of free
One side affect of free flowing intakes/exaust is it might take longer to warm up. My old car (92' sl1) would never go past the 1/3 temp mark in the winter.
I think that the stock size exaust pipe is best for mpg. You might get more HP is high rpms but, you lose HP at low rpms.
http://www.spswebpage.com/tech/index.php?articleID=a5207vs5223
on this site they gained several HP by removing the muffler. (but they don't show the dyno sheet under 4000rpm
2008 EPA adjusted:
Old 09-30-2005, 06:02 PM   #8
a smaller dia intake and
a smaller dia intake and exhaust will not get you power, lol
dfoxengr is offline   Reply With Quote
Old 09-30-2005, 06:12 PM   #9
But!
But will a smaller intake and exhaust gain you mpg or will going larger increase both power and mpg?
Old 09-30-2005, 06:22 PM   #10
a 3" exhaust on a stock
a 3" exhaust on a stock civic wont help you. it's all in what your motor needs.
nor will a 1" intake on the same car help you at ALL
you need to "design" your complete engine setup to where all parts work together.
GS FAQ/Glossary, Busted/Confirmed Mods, Archive SVOboy General Fuel Topics 80 04-18-2020 04:15 AM
Audi S3 AlexC Fuelly Web Support and Community News 2 05-23-2011 02:30 AM
Suggestions needed Matt Timion Fuelly Web Support and Community News 80 03-28-2009 05:37 AM
Minimize Computer Power Consumption Mighty Mira General Discussion (Off-Topic) 13 12-09-2007 01:27 AM
