Originally Posted by RoadWarrior
Ah, but what if I steal parts off a less efficient vehicle to equal the configuration of a newer more efficient model of the same vehicle.... Like later Escorts have different TB and injectors, but I could steal equivalent ones from a couple of other Ford products that get worse than the older model Escort MPG...
Can these parts you're taking off a vehicle, while may have come from one vehicle, can also come from another? Ala Civic CX vs VX? (In Respect to the transmission) If so, assuming is a true fuel economy booster, then you should use the higher rating vehicle. So if you put a CX/VX tranny into your DX Hatch civic, I'd probably go with the CX Fuel economy rating assuming it actually came from a CX not only because your DX engine doesn't have lean burn and Vtec like the VX does, but because you're not "depriving" (so to speak) a VX of its fuel economy. However if you swap in a CX tranny into a VX because your VX tranny went bad, I'd still stick with your VX fuel economy rating since you're theoretically trying to keep a VX on the road opposed to taking one off the road when you put it into a completely different trim altogether.
Just try to figure out why you're doing these modifications, is it for a performance boost or fuel economy boost. Can and is this part found in a more fuel efficient trim as well? Some cars the only difference is the gearing of the transmission like the Cobalt XFE and in that case, if you're putting a Cobalt Engine from an XFE into your Vanilla Cobalt, then your fuel economy numbers shouldn't change and you're probably doing it because your engine went bad, not because you're trying to get a fuel economy boost/get ahead of your EPA numbers. But if you put the XFE tranny into your Vanilla Cobalt, then you should be using the XFE EPA numbers as your baseline, NOT your Vanilla Cobalt's.
