LRR Tires (I know been asked 1000 times) - Fuelly Forums
Old 01-30-2007, 12:03 PM   #1
GasSavers_Jack's Avatar
After reading everything I could find here on Gassavers and what I could find else where I am still stumped on the LRR tires for my VX.
Quoted RH77 on Feb 2006:
Originally Posted by rh77 View Post
OK CR's policy is that reprinting data is OK as long as it's "noncommercial, educational purposes only", so I think we're cool here.
The tires tested with the "Excellent" rolling resistance rating in the "all-season" category, in order of best overall rating of other factors combined, with 80% as the top tested :
1. Michelin X Radial DT (only available to shopping club members, i.e. Costco, Sam's Club, etc.). Rating: 79%.
2. Michelin Agility Touring (Sold only at Sears). Rating: 62%.
3. Michelin Harmony. Rating: 61%.
4. Hankook Mileage Plus GT H707. Rating: 58%.
5. Kumho Touring 795 A/S. Rating: 57%.
6. Toyo 800 Ultra. Rating: 51%.
7. Sumitomo HTR T4. Rating: 44%
All models can be researched at TireRack.com or similar sites to get a feel for performance. It's the motherlode! Let me know if other information is required, and I'll post it. Now I can buy new tires, finally...
The only ones that I can find close to my size (165/70/13) are these:
http://www.tirerack.com/tires/tires....ring+A%2FS+795
The Kumhos in a 155/80SR13
Set of 4 for about $160 to my door. Anyone have any reasons why I should not do that? For some reason I am just afraid to "pull the trigger" on this.
It would be alot easyer if LRR tires were advertised as LRR and you didnt have to have some magic powers to figure it out.
Thanks in advance for input.
See my car here:
Old 01-30-2007, 05:54 PM   #2
CR Publishes Rolling Resistance
I went back to the site to get more info, but it requires a subsription of $6/mo. or $29/year for the LRR ratings.
They did say this:
"Consumer Reports is the only organization that regularly publishes a rolling resistance score as part of its ratings of important tire-performance criteria. We note rolling resistance for all the tires we test except winter tires, where traction and grip are of paramount importance."
The latest test of tires was 11/06 -- so for piece of mind you may do a one-month trial and look at additional options.
Here's the link to the LRR page.
Finally it looks like someone is testing this critical FE variable.
Old 01-30-2007, 07:10 PM   #3
I just put a set of kumho a/s 795s on my hx rims, and these are great. They grip the road much better than the re92, and roll just as easily it seems. they come in 165/80/13 and 175/70/13 too from tirerack.
Check out this survey of the best a/s tires, I assure you these tires will satisfy.
http://www.tirerack.com/tires/survey...ay.jsp?type=ST
budomove is offline   Reply With Quote
Old 02-06-2007, 03:25 AM   #4
Jack,
The Sumitomo HTR T4 is available in size 165/70R13 and its maximum psi is 51 (which should give it an advantage over other LRR tires whose psi max is 44):
http://www.sumitomotire.com/catalogs...at_Rev5.05.pdf
Old 02-06-2007, 12:22 PM   #5
GasSavers_Ryland's Avatar
I have 155/80 R13 snow tires on my vx right now and they are great, my other tires are firestone f570 165/70 R13, and are pretty sweet, altho not as low rolling resistance as I was hoping for, they grip amazingly well, and role better then any 175/70 R13 tires I've ever had (175/70 is just to wide, it's absurd) one of the sites posted in the last few days offered 145/80 R13 tires, I'm tempted to get some next time I need new tires.
Old 02-07-2007, 05:34 PM   #6
Tirerack had them at my door today. (the 155/80/13's) I will have them mounted tomorrow. The back set will go on tomorrow too but the fronts will have to wait until the snow tires and rims come off in April.
See my car here:
Old 06-30-2007, 07:21 PM   #7
Member
Jack,
How did the kumho a/s 795s 155/80 tire work out? Any gain in MPG
ron22 is offline   Reply With Quote
Old 06-30-2007, 09:23 PM   #8
SL8Brick's Avatar
FWIW, I've had the Toyo 800 Ultras on since Nov.06. Really good wet/dry grip, very smooth, but a little noisy at times. No change in FE 4me.
SL8Brick is offline   Reply With Quote
Old 07-01-2007, 04:59 PM   #9
brucepick's Avatar
Best data I found was to find the latest Consumer Reports issue re. Tires. They do rate them for rr, using their typical 5-point scale with the red and black dots. Unfortunately tire models change pretty quickly sometimes so what's available may not match what did well in Cons. Repts.
The other bit I decided on was to get tires rated at least 44 psi. If I can find/afford tires rated at 50-something I'd prefer that.
Old 07-01-2007, 05:24 PM   #10
88HF's Avatar
I had a dream that someone on gassavers was using powerwheels type hard plastic tires as LRRs. They were big and red.
my favorite thread
New Feature: Loan and lease cost labrie Fuelly Web Support and Community News 1 02-08-2012 01:12 AM
Windows vs. A/C DHA General Fuel Topics 7 11-19-2009 06:57 AM
Engine Builder's Notebook GasSavers_katman General Maintenance and Repair 8 07-13-2006 10:12 AM
Another Heavy-Weight Hybrid Contender 95metro Hybrid Vehicles 0 06-05-2006 07:12 AM
