VX with rattle/hesitation issues - Fuelly Forums
Old 12-28-2008, 08:17 PM   #1
Hey guys,
So I haven't had my VX for very long and I'm in the process of cleaning it up and changing out bad parts. Recently, I've had the timing belt and water pump replaced. The timing belt I think was put on too tight and is causing a sort of whirling noise, but I can have that adjusted. Before either of these two parts were replaced though, I've had an issue with a rattle that comes on in 1st gear after 1500 rpms and 2nd gear after 2000 rpms. I do have a bad input shaft bearing that I will get fixed soon, but could it be the input shaft bearing that is making the noise in 1st and 2nd gear? The input shaft bearing does make a noise when my foot is off the clutch at idle. But when I rev the engine at idle it doesn't make the rattle noise I hear when I'm driving. I have posted a video on Youtube demonstrating the sound. Also, I've noticed that when I shift into 2nd gear and if I floor it, it'll start hesitating for a good 3 seconds and then continue on. I've also included a clip of this. Can anyone help me with this? Thanks
Clip of the rattle noise:
http://www.youtube.com/watch?v=bpg2QiLSp8M
Clip of the hesitation (starts at :09 until :14):
http://www.youtube.com/watch?v=fqnisNSFy4E
poi_boi_23 is offline   Reply With Quote
Old 12-29-2008, 05:25 PM   #2
suspendedhatch's Avatar
I can't hear anything but wind noise. But it's very common for the exhaust heat shields to rattle on these Civics.
Old 12-29-2008, 08:36 PM   #3
I just replaced the input bearing on a '97 HX with 150k. Sounded almost identical to that.
Diy it here:
http://www.d-series.org/forums/showt...tranny+sealant
As for the hesitation I've heard the O2 sensor could be the issue (could) or it can sometimes be the throttle body shafts wearing out and creating a vacuum leak when they are moved.
Daveedo is offline   Reply With Quote
Old 01-01-2009, 06:50 PM   #4
That is a seriously bad "hesitation" problem, more like a full on mis-fire. What is the year and mileage of your VX and how long has the o2 sensor been on?
My 1992 VX had just over 100,000 on the second sensor and had (by comparison) more of stumble, studder at exacly those same RPM's. The cure in my case was a new L1H1 and it is flawless now. They are available for $99 as I have posted in other threads.
Regarding the rattle sound, it might be easier to suggest but I don't know the when the sound that's bugging you shows up without a reference to the track as you posted for the hesitation.
SCoupe is offline   Reply With Quote
Old 01-02-2009, 11:56 PM   #5
Thanks for the replies,
Well after messing around with the car some more I realized I needed to change out some more parts.
- O2 Sensor is black as night
- Exhaust Manifold has a crack down the middle where the O2 sensor is
- Spark plugs are bad/ Plug wires don't properly fit
So far I've ordered all these parts: 5 Wire 02 Sensor, Fed ECU, Conversion Harness, NGK Spark Plugs, Fuel Filter, NGK Plug Wires
I'm also soaking the EGR valve and cleaning the EACV and will be cleaning the EGR ports tomorrow
I have another question on the exhaust manifold.. is the Dorman 674-545 exhaust mani. a good replacement? I'm not sure if it's a reputable brand but I do see Autopartsdirecttoyou.com and Rock Auto both sell the Dorman exhaust mani. as a replacement, and so I'm wondering if this would be ok? Or should I get a used DX manifold?
P.S. My MPG is at 33 which is horrible! But I'm doing everything I can to get it where it needs to be
partial fuel up... pbfoot Fuelly Web Support and Community News 6 12-29-2013 10:54 PM
Hello All GasSavers_MikeD Introduce Yourself - New member Welcome 3 07-23-2007 10:34 PM
Blast from the past: Mobilegas Economy Runs? Spule 4 General Fuel Topics 8 11-20-2006 07:47 PM
