Read my spark plug... - Page 7 - Fuelly Forums
Old 05-02-2011, 05:41 AM   #61
GasSavers_Erik's Avatar
Re: Read my spark plug...
Yes- that is the sound of spark knock at :10 and :31.
Old 05-02-2011, 06:43 AM   #62
I was sure it was fuel starvation, that's exactly what it felt like, but it went away when I did the thing with the vacuum lines...unless somehow the manifold vacuum was interfering with the carburetor through its vacuum connection (again, if the plastic thing isn't doing its job right), but I don't see that causing that symptom.
Old 05-03-2011, 12:59 PM   #63
add|ct's Avatar
Going back to the anti-seize choices, I wound up buying some of this:
http://shop.advanceautoparts.com/web..._7160116-P_x_x
Interesting difference at Napa?
https://napaonline.com/Catalog/Catal...282487282&An=0
It specifies on the back of what I purchased:
"Use in spark plug installation on aluminum cylinder head-equipped engines." ... Use on: Spark Plug Threads when installing in aluminum or cast iron heads.
Appears that there isn't much difference between the one I have and the Napa product that says "Copper" on the front? Is this because Permatex/Napa have re-bandaged the product for those stores?
'92 Civic VX, Canadian model
Old 05-03-2011, 01:14 PM   #64
add|ct's Avatar
Is spark knock the same as pinging/knocking in general?
Old 05-03-2011, 02:00 PM   #65
Spark knock is the same as pinging, but different from a rod bearing knock or main bearing knock.
Old 05-03-2011, 03:01 PM   #66
add|ct's Avatar
A result of fouled plugs or severe carbon deposits around electrode/combustion chamber? Or could it also be a result of ignition related components?
Old 05-03-2011, 04:38 PM   #67
Detonation can result from fouled plugs, severe carbon deposits, overheating, low octane gas in a high compression engine, a bunch of other things I don't remember, and of course it can DEFINITELY come from messed up ignition system or incorrect ignition timing.
I don't know if you'd call it "spark knock" when it's not caused by the ignition system, even though it's essentially the same process and symptom.
Incorrect ignition timing (caused by vacuum advance not hooked up right) is what caused my spark knock.
Old 05-03-2011, 07:31 PM   #68
add|ct's Avatar
^Ah, I see what you mean. So, have you retarded the timing some?
Old 05-04-2011, 04:39 AM   #69
No, in the name of the science of fuel economy I'm risking finishing this tank before I fix it. This looks like it's going to be my best tank ever. I'll know tonight.
Before I leave work I think I'm going to change that distributor vacuum hookup which should give me the retardation I need.
Old 05-04-2011, 03:14 PM   #70
Well it was raining too much to go under the hood wearing my work clothes. I'll do it tomorrow or something,
I was expecting this tank to be a big improvement over the last tank but it's about the same, slightly improved.
US / metric switching problems gory Fuelly Web Support and Community News 4 01-24-2011 02:04 AM
Tracking Monthly Fuel Expense Taser Fuelly Web Support and Community News 2 11-09-2009 11:40 PM
Halfway Home! '93 Civic CX tucsonron Transmissions and Running Gear 8 07-01-2009 08:45 AM
Civic VX L02 Ecu Cali GasSavers_maxpowers For Sale 0 09-27-2008 07:01 PM
1995 VX for $4500, is it worth it? Talerien General Discussion (Off-Topic) 4 06-12-2008 04:01 PM
