My T-100 aero cap... - Fuelly Forums
Old 12-24-2010, 06:15 PM   #1
BamZipPow's Avatar
Send a message via AIM to BamZipPow
Talking My T-100 aero cap...
Over at ToyotaNation...I documented my build of my T-100 aero cap.
Here's some different looks of the hatch configurations...
Closed up with a proposed boat tail length...
Standard cap height...offers a great view when backing up!
Rear view...
Wide open...
Rear view...
Keep in mind that I designed this strictly fer aerodynamic testing...not fer security. The hatch is easily removed fer tall items just by removing 2 screws. My other goal is to be able to easily disassemble the entire cap just using one person.
I have to pins to keep the hatch from opening on it's own when I'm driving down the road. It also keeps people from opening the hatch but they can always open the tail gate since it's not lockable.
Estimated costs is probably around $40 since the coroplast was free and I'm reusing most of the wood/hardware from my first belly pan project. Estimated weight is around 40-50lbs? Not exactly sure though...
BamZipPow is offline   Reply With Quote
Old 12-25-2010, 04:10 AM   #2
Re: My T-100 aero cap...
Looks great!
I wish I could come up with free coroplast that large.
Old 12-25-2010, 06:14 AM   #3
BamZipPow's Avatar
Talking Re: My T-100 aero cap...
Looks great!
The hatch is basically made from 3 sheets of 4x8 coroplast. The two bottom sheets overlap each other like a hand fan...close together at the top (narrow) and then spread out at the bottom (wide). I have a third 4x8 sheet that covers that up...makes it more stable.
Old 12-25-2010, 09:49 PM   #4
BamZipPow's Avatar
It survived the heavy rain last night...just a little bit of water in the right rear corner of the bed. I'll have to put some camper top foam on the sides where the hatch closes on top of it. I hope to have the backside buttoned up soon with some plexiglass...
Here's what the cap looks like as I prepare to go on a trip up North...
Old 12-30-2010, 11:59 AM   #5
BamZipPow's Avatar
Buttoned up the rear with some Lexan I got at Lowes and headed up North. First tank from Houston to Ardmore was 25mpg cruising at 65mph. Second tank was filled with some ethanol free gas and yielded 28.86mpg cruising at 65mph. Weather was rainy and temps were in the upper 40's. I was carrying about an extra 400lbs of passengers and their luggage...this was above my standard tool/gear load out.
Old 01-18-2011, 06:43 AM   #6
BamZipPow's Avatar
Trimmed up the front edge...
Old 01-18-2011, 03:29 PM   #7
BamZipPow's Avatar
Gas struts are mounted to the hatch!!
Old 01-21-2011, 03:20 PM   #8
BamZipPow's Avatar
Put in metal straps to hold the hatch open at the standard camper height fer those times I need the hatch open but not all the way open. When they're not needed...I just swivel them out of the way. I use the same pins to keep the straps in place as I do when I lock the hatch down.
I guess I could make some inserts to eliminate the gap between the hatch and the sides...
Old 02-04-2011, 08:30 AM   #9
KLP
Can you post your MPG numbers for both before and after the modifications so we can know how well this worked. If it works I may try it myself. Thanks
KLP is offline   Reply With Quote
Old 02-09-2011, 05:30 AM   #10
BamZipPow's Avatar
Wink Re: My T-100 aero cap...
I've documented my fuel mileage in my fuel log...
http://www.gassavers.org/garage/viewgaslog/1723
More Fuelly graphics? reppact Fuelly Web Support and Community News 5 11-30-2008 08:07 PM
Can you identify the wires in my o2 sensor? Matt Timion General Maintenance and Repair 9 07-11-2007 11:13 PM
Looking for someone to forward an eBay package from US to Canada MetroMPG General Discussion (Off-Topic) 9 06-27-2007 02:40 PM
Have you ever participated in a 'Cruise Night' in your city? Peakster General Discussion (Off-Topic) 20 03-27-2007 03:23 PM
I'm going nuts! buying tires soon lovemysan General Fuel Topics 11 12-23-2006 08:13 AM
