T-100 belly pan and side skirts... - Page 7 - Fuelly Forums
Old 12-07-2010, 06:47 AM   #61
Re: T-100 belly pan and side skirts...
Are you planning to leave the cap and equipment off? If so, lowering the rear should be very easy. It is on other pickups where I've read about it...there's usually a few different ways to do it for free/cheap.
Old 12-07-2010, 07:37 AM   #62
BamZipPow's Avatar
Send a message via AIM to BamZipPow
On the T-100...it's not so easy to drop the rear down on the 2WD as the spring perches are on the bottom of the axle. I could put some blocks in between the axle and the springs (which drops the shock plate closer to the ground) but I'm not a big fan of blocks and the safety hazards that go with them. And...I would have to git longer shocks fer the rear. Besides...I need the utility of the bed and will need to carry my tools and gear at some point in time.
I'm currently working on building a lightweight aero cap (not fer security) that I can easily take apart and store when I need to...
The first step I'm doing is making a half tonneau to test my rail system.
BamZipPow is offline   Reply With Quote
Old 12-16-2010, 03:05 PM   #63
kamesama980's Avatar
Safety of blocks depends on the blocks and installation. the big 3 all use blocks on the larger trucks, granted they're steel or cast iron and beefy as all get-out, not extruded aluminum like most for sale.
a guy in my school just had to replace a set because the road salt and water collected in the cavity and they corroded the aluminum away and one side partially collapsed.
They also exaggerate axle-wrap and wheel-hop, though I doubt you do too many burnouts on a FE-minded truck.
-Russell
Old 12-18-2010, 06:00 PM   #64
BamZipPow's Avatar
Slapped together a quick test aero cap...
Old 01-09-2011, 12:29 PM   #65
BamZipPow's Avatar
Extended the rear diffuser out about 17"...
Old 02-16-2011, 09:40 AM   #66
Cool Re: T-100 belly pan and side skirts...
Hay you guys I have a Chev S10 with a 4 cyl 5 speed that is baceuallt the same truck and If I am really careful at high atitudes it does 37mpg and I was wondeering if yuo have tried any thing like gas shut off switch, or the hydrogen injecting , any of the performance chips or the high flow exaust systems with any good results?
I would apperacate any for thought you have .
Thanks
GasSavers_gashog is offline   Reply With Quote
Old 02-17-2011, 07:44 PM   #67
BamZipPow's Avatar
Wink Re: T-100 belly pan and side skirts...
Thanks
No...I haven't tried those things because they don't have anything to do with my belly pan thread.
Old 02-17-2011, 07:47 PM   #68
BamZipPow's Avatar
Since I went with the metal stud frame work...I didn't git a real chance to update my engine bay belly pan. So I found some materials and finally fit it to my new framework. I was able to reuse about 50% of the existing materials.
This was prior to required trimming to clear the tires when turning. At least it's smooth now..
Old 03-06-2011, 09:26 AM   #69
What is the before/after MPG?
Thanks for proving that pickups get better mileage with the tailgate closed.
Tear anything up on curbs yet?
Civic VX miss under load oh95vx General Maintenance and Repair 54 07-21-2011 07:57 PM
Joint Membership with GasBuddy? Badams Fuelly Web Support and Community News 2 07-01-2011 11:14 PM
Is there any way to make my gaslog L/100 KM instead of MPG? GasSavers_broadwayline Fuelly Web Support and Community News 16 10-31-2008 12:49 PM
where do I buy insulation? Matt Timion General Discussion (Off-Topic) 5 05-24-2006 07:40 PM
IAT Sensor Mod (Resistor Mod) SVOboy General Fuel Topics 28 10-17-2005 06:08 PM
