New '92 Civic DX (soon to be VX) - Page 2 - Fuelly Forums
Old 11-28-2007, 06:39 AM   #11
GasSavers_TomO's Avatar
Originally Posted by first350 View Post
I plan to shave it to increase compression for FE...I'm having a little trouble finding good info on what kind of compression ratio to aim for that will still allow me to run 87 octane, but at least 1 person is saying 10.5...so I'll probably aim for 10 to be a bit conservative.
10.5 is all the higher I would go and still be able to stay with 87 octane.
I'll do all the other easy stuff too: smooth out casting lines, port match,...I had thought of increasing compression by going w/ longer rods (you can usually get a higher compression ratio w/out detonation this way), but opted not to b/c I'm trying to keep costs low.
-Peter
You don't really want to mess with the stroke on the D15Z1, it sits right at a rod/stroke ratio of 1.62 which is perfect for low resistance rotating as well as lateral pressures of the piston.
If you really want to increase the FE of a VX, invent and aperture style throttle body. It would offer better, less restricted flow of air into the intake manifold.
Honda Civic VX Info/Links
Old 11-28-2007, 11:08 AM   #12
aperture style TB - similar to a camera shutter? sounds like a good idea if you could get it to flow like a velocity stack for all throttle positions...I should start tinkering with this idea...
*wonder if smaller multiple throttle bodies would work...have them open up sequentially;
say you have 4 TB's:
full throttle - all 4 full open
freeway 65 MPH partial throttle - 1 full open, 3 full closed
you would choose how many TB's by sizing them such that 1 TB fully open would match power for freeway cruising.
first350 is offline   Reply With Quote
Old 11-28-2007, 11:49 AM   #13
GasSavers_vxhatch's Avatar
taller/thinner
i plan to run taller/thinner tire if I can find one...so the final ratio will be even taller!
Ah, taller/thinner - great qualities in a............................ tire. My car has 155/80/13 Kumhos. Taller/thinner than stock. iirc, max rated pressure is 42psi, wish it were higher. I bought the car with these tires, so I can't say whether they are a benefit to FE or not. I'll likely go back to the stock size, if I can find em, once these wear out.
Doug
GasSavers_vxhatch is offline   Reply With Quote
Old 11-28-2007, 12:54 PM   #14
Doug
lol - I actually just bought the same tires...$130 shipped to my door - FTW! (I'm accustomed to paying $200+ per tire for my 350Z...I luv this civic!)
Installed 195F Coolant Thermostat ... Reset ECU? cfg83 General Maintenance and Repair 13 04-06-2011 11:54 AM
Available Members or New Team Formation rh77 General Fuel Topics 164 03-14-2008 02:07 PM
Concentrating photovoltaics advancements ... cfg83 General Discussion (Off-Topic) 4 03-01-2007 06:24 AM
2006 Toyota Camry LE rh77 Car Reviews 0 01-24-2007 07:17 AM
Finally got some LRRs rh77 General Fuel Topics 4 10-03-2006 08:16 PM
