CRX HF Transmission Rebuild - Page 2 - Fuelly Forums
Old 01-12-2006, 01:08 PM   #11
His fourth gear is actually
His fourth gear is actually as long as the cx/vx fifth, though the final drive is pretty crappy.
Old 01-12-2006, 02:03 PM   #12
Compaq888's Avatar
Re: Nice build, but I'd never do
Originally Posted by Compaq888
Nice build, but I'd never do it on my car. I have no tools and I have the most economical tranny that was built for my car.
But do you have the most economical tranny that fits your car? The HF transmission isnt' designed for our cars, but it fits. Maybe a sentra transmission has longer gears and fits in your car. It might rob a little power, but will save you $$$ in the long run.
Yes this is the most economical tranny that fits my car. You see the 93-99 trannies have very long 3rd and 4th gears. And plus the diff is geared very low. The 2000 and 2001 trannies have the same exact gearing but the diff is geared higher. The same thing with the 02 altima. Same exact gears but the diff is geared higher.
This is the best tranny unless I put in a hybrid tranny that is a manual and has the 5th gear very very low. Which means on the street I'll get 25+mpg and on the freeway 35+mpg
The sentra tranny is even geared higher. I've checked.
Old 01-20-2006, 12:33 AM   #13
you do realize the weight
you do realize the weight difference between the sedan and the crx hf, right?
2.95 final or 3.25?
if it's 2.95 you're going to hate yourself for putting it on.
make sure you run tests to see if it yields you any benefit in mpg.
GasSavers_bense is offline   Reply With Quote
Old 01-20-2006, 04:48 AM   #14
Moderator
GasSavers_DaX's Avatar
I do realize the weight
I do realize the weight difference. I'm not going to hate myself, as I already drive like a grandma. I have another Civic I can drive when I want to go fast.
Old 01-20-2006, 08:11 AM   #15
Matt Timion's Avatar
Re: you do realize the weight
2.95 final or 3.25?
my sedan (1989) = 2211lbs
CRX HF (1990-1991) = 1967lbs
Add one fairly large passenger to the CRX HF and the weight is the same.
My understanding is that the HF first and second gears are both rather "peppy" so that accelerating is very achievable.
Old 02-22-2006, 04:53 AM   #16
Moderator
Much progress has been made.
Much progress has been made. I hope to update later today or tomorrow with many pictures on my progress.
Old 02-23-2006, 04:21 AM   #17
Moderator
Ok, TONS of pictures as
Ok, TONS of pictures as promised:
Are we ready to rebuild yet? Here's my corner of the garrage with all my tranny guts and lots of new parts in pretty little bags with red Honda stickers on them.
An essential tool when rebuilding a tranny is a bearing puller set. This is my bearing separator tool in action on one of the diff bearings.
Here is the puller part attached to the separator. It can handle 10 tons.
Success. Both bearings removed from the diff.
Pulling the main shaft end bearing.
New main shaft end bearing installed. I didn't have to use a press for this one. This is the only part of the main shaft that I'm dealing with on this rebuild, so it goes to sit in a box for now.
When you first pull out the main shaft, be very careful not to drop, lose, or mix up these two washers that are on the shaft. One is a spring washer and the other is a shim...they're HIGHLY important.
Another essential tool is the seal driver set I bought.
This is the main shaft seal. Note that the way I am holding it is how it goes in...the side with the words on it does NOT see oil.
Seal driver in action on the main shaft seal.
Main shaft seal in place.
Now driving in the main shaft bearing [often referred to as the ISB or input shaft bearing].
Aren't brand new bearings just sexy? ISB in place.
A new pickup magnet. It's a pretty good idea to put one of these in, as your old one will be pretty gunked up.
This is where the new magnet will live.
This is the counter shaft roller bearing. Underneath it is the counter shaft's oil guide plate [white plastic]. I bought a new one for this rebuild, but decided not to install it, as the old one looks fine [no chips, cracks, or deformation].
This is the main shaft shim. It's located in the deep part of the tranny housing. You have to pull it out to get to the main shaft oil guide plate.
Old main shaft oil guide plate. This one was pretty deformed from heat. Peace of mind will come with a new one installed.
New oil guide plate installed and main shaft shim reinstalled.
To replace the shift rod seal, you must remove the two gold bolts in the lower right of the picture.
Underneath one there is a ball and spring. Carefully remove these.
The shift rod is now free to be pulled out.
See how dirty my bell housing is? If I wasn't so lazy, I'd clean it now.
Channel locks encourage the old shift rod seal to come out.
Channel locks = 1; Shift rod seal = 0.
This is where the old shift rod seal went. Don't freak out when you see the black washer under there...it's not part of the seal and is supposed to be there, so don't try to dig it out!
I found it easiest to prop the bell housing up against a wall so that I could have a perfect vertical to drive the new shift rod seal in place.
New shift rod seal in place.
This part of the internal shift linkage fell out when I turned up the housing. Just fish it back into place.
Reinstall the shift rod, then drop the ball into place...
Followed by the spring...
Then the bolt. Re-torque to spec.
Mount the counter shaft in a vise. Be sure to protect the teeth when you mount it. I used some polycarbonate scraps.
Use a BFW [big freakin' wrench] to remove the countershaft nut. A new nut should be used and staked each time.
Another spring washer. Be sure to not put this on upside down when reassembling.
Use the puller to remove the two bearings. The top bearing has a slot in it for the snap ring in the housing.
That's all for now. I'll take pictures when I visit my friend's shop with the 30 ton press !!!! The diff bearings and the counter shaft bearings must be pressed on, or heated then quickly slid on [I've done it this way, but don't feel comfortable doing it].
Old 02-23-2006, 08:20 AM   #18
okay, you looking at this
okay, you looking at this makes me have two questions.
1) Do I need a bearing puller tool in order to remove my throwout bearing?
2) If I take a few pictures of my transmission, can you tell me what I might need to replace? Simple things would be good. I have no experience with transmissions at all and I don't want to put it on the engine if it's missing pieces.
Old 02-23-2006, 09:24 AM   #19
Moderator
Throwout bearing removes by
Throwout bearing removes by hand...very easy and you don't even have to open the transmission case. I'm going to document that, but I haven't gotten that far yet.
Yeah, take some general pictures of your transmission and I'll tell you what I think. Are you installing an HF transmission as well?
Old 02-23-2006, 09:42 AM   #20
krousdb's Avatar
Re: Throwout bearing removes by
Another question. Is it fair to say that with the exception of slightly different gearing and a much lower final drive, the HF transmission is the same as a DX transmission? Could one take a DX and change the differential gear to make an HF?
My ignorance of the inner workings of transmissions should be quite evident. I have changed a few a long, long time ago, but never actually taken them apart.
How to change fuel type JayHoe Fuelly Web Support and Community News 3 06-15-2011 12:14 AM
gasoline and veggie oil, to much time to think. GasSavers_Ryland Experiments, Modifications and DIY 35 06-30-2008 05:20 PM
Am I ever going to be a hypermiler???? Compaq888 Hypermiling 33 05-15-2006 05:44 PM
Friction Reducer kjvman General Fuel Topics 1 01-22-2006 06:52 PM
thought this article was interesting bagpipe goatee General Fuel Topics 1 09-06-2005 09:57 AM
