This was a while back, but remember "Molecule" and his GS-R?
Thread.
Basically he had a built-up JDM, 3-stage VTEC 1.5L in an Integra GS-R with a Nissan Skyline RB20 Turbo set to Zero PSI. 35mpg and all kinds of HP on tap.
So if I understand it correctly, if you reduce the pumping losses with a super-mild turbo at 1-bar, then you can gain some FE. This results in 14.5 PSI at the MAP sensor, which is essentially standard atmospheric pressure (29.92 inHG for US weather watchers). But, that doesn't mean the turbo pushes that much force, just enough to make up the difference.
What ever happened to Molecule???
RH77
