06-30-2013, 07:47 PM
Gas Mileage with 2 identical drivetrains but 2 different drag coefficient
I have a Talon TSI AWD Turbo and a Mitubishi Galant VR-4. Both have identical Turbo/AWD setups and engines.
The cd on the Talon is .29 and on the Galant it is .34.
I was just wondering how much worse off the Galant is if all things are equal even including weight and tune.
Thanks
92 Protege DX 5 speed - Poor Man's Hybrid 40.96 MPG (city)
Thicker 2 row radiator, walmart hubcaps, Pepboys tires, 10w 30 Castrol HM, Jensen CD player, Roadmaster speakers, ebay hi-flow air filter, autolite 3924 plugs, stant superstat, NGK blue 8mm wires, LeBra car bra, no Exhaust Manifold heat shield, MX-3 Seats, bad A/C compressor
07-01-2013, 06:57 AM
It will come down to the trip. In town they will be the same or close enough not to matter.
I can't answer how much, but you probably won't have a noticable difference until you get up to highway speeds.
07-01-2013, 09:34 AM
Well, the example I can come up with is the 2010 Escape Hybrid fwd and the 2010 Fusion Hybrid fwd. The both have the EXACT same powertrain. The Fusion is rated for 41 City 36 Highway 39 Combined, the Escape is 34 City 31 Highway 32 Combined. That's basically a 7 MPG difference in the combined rating.
07-01-2013, 11:08 AM
I don't know how reliable it is but this web site says they have different final drive ratios which would greatly affect the mileage.
I do want to say that there is a huge weight difference too but I am not finding it. I assume that the truck is assumed to be used for more hauling and thus beefed up vs the car.
2010*Ford*Fusion Hybrid Specifications
2010*Ford*Escape Hybrid Specifications
There again, I don't know the reliability of the site and it may be dependent on package and options.
07-01-2013, 03:15 PM
Thanks all, the trip is almost exclusively highway. I know it is hard to figure out, but thanks for the examples. Both cars don't really weight the same thing, but I was just trying to simplify things a little. The Galant has been gutted for weight savings so in actuality it may be similar to the Talon in weight. It is not the same as comparing say an LT1 Camaro and an LT1 Impala SS. The weight difference is much closer to begin with between the 2 vehicles. The Galants weren't that large back then.
07-02-2013, 08:26 AM
For a highway trip weight won't matter. If you're sure the entire drivetrain is identical (transmission ratios, final drive ratio, tire size) then you're looking at aerodynamic differences and probably some rolling resistance differences too.
Also don't forget that aerodynamic drag is not just the coefficient, but the coefficient multiplied by frontal area. Does frontal area differ much?
07-10-2013, 10:52 AM
I dunno if weight won't matter, but perhaps it will matter less, particularly in flat areas. But hilly areas it will certainly matter on the highway.
three stripes the charm!
07-10-2013, 11:02 AM
I don't see why. You store energy while ascending and release that energy while descending, there's no reason to lose anything. If anything it'd be an advantage, allowing you to P&G on the highway while keeping a steady speed.
07-10-2013, 11:13 AM
I get some of my best mileage in the mountains. It may totally suck going up the mountains, but going down more than makes up for it in my case.
07-12-2013, 06:45 AM
Mountain area should almost always be worser for mpg, because when going down there's definitely corners where you need to brake/engine brake and you can not keep on 'gliding' downwards.
That's all loss of energy.
Can imagine it's a bit better on highways, but for safety you need to keep a bit of steady speed, no?
