New shoes (aka tires) - Page 2 - Fuelly Forums
Old 06-22-2007, 11:59 AM   #11
cfg83's Avatar
caprice -
Originally Posted by caprice View Post
yeah the best thing to do is verify the odometer with GPS. Instead of reling in the specifications.
On my old Daewoo, the speedometer was right on with stock size tires, odometer off, then with oversize diameter tires, the speedometer off a little and odometer dead on.
The road grove following is a side effect of higher TP. Im my experience, it gets worse with more air. That is when you know you have reached the limit for that tire. Also sometimes you can "feel" paint stripes though the handling.
I backed it down to 40 PSI and the road grooving diminished, so I think I will leave it there for now. I did another Odometer test and got the same result :
GPS:Car Odometer
32.83/31.80 => 32.8 / 31.8 = 1.031 => 3.1% error
Old 12-05-2007, 09:20 AM   #12
cfg83's Avatar
Hello -
Here is a quick GPS update (in miles) :
Code:
              Car Odometer    GPS       GPS/ODO    % Correction
2007/12/01    30.4            31.2      1.0263     +2.6%
2007/12/05    31.4            32.3      1.0286     +2.9%
What does this mean? My one size larger tires, currently running at 50 PSI, are still showing a greater than 2% change when compared to the odometer. Since I use my odometer for calculating MPG, my +2% correction in my gaslog is still valid (whewwwwww! ).
Old 12-05-2007, 01:13 PM   #13
You're supposed to lower sidewall profile a step when increasing width to help offset speedo miss-calibration, so those new tires should've been 195/60's...
Didn't the installer know this?
The wider tire will help some, I like them myself.
But I doubt it helps mpg any, I didn't see it hurt either thou.
Old 12-05-2007, 11:33 PM   #14
cfg83's Avatar
8307c4 -
I told them I wanted this tire size, . The idea is to increase the diameter of the tires and thereby create a "taller gearing" for the car. I don't mind the odometer correction because it's "proof" that the tires are bigger (aka working) as intended. Orrrrrrrr ........... the odometer was off by X amount already, .
New Feature: Loan and lease cost labrie Fuelly Web Support and Community News 1 02-08-2012 01:12 AM
More fun on FUELLY brytrkr1 Fuelly Web Support and Community News 3 12-06-2009 10:41 PM
Newb FAQ Red Tick General Fuel Topics 4 06-15-2006 01:34 PM
MetroXFi changed his name! SVOboy General Discussion (Off-Topic) 26 04-09-2006 06:38 PM
