No freakin way! - Fuelly Forums
Old 08-05-2007, 08:40 PM   #1
No freakin way!
You won't believe it! I bet someone calls me a liar! Check out my most recent gaslog entry!!!!! Its late, so Im going to sleep!!!!!!!!!!
Nic
Old 08-05-2007, 08:42 PM   #2
skewbe's Avatar
Nice, I bet you'll be doing it without thinking about it before you know it.
(course it was a short tank)
Standard Disclaimer
Old 08-05-2007, 08:48 PM   #3
I filled up at half tank, so it wasnt really that short. Nearly 300 miles...
I figure I EOC'd about 90 miles out of 298. Diligence!
Old 08-05-2007, 09:26 PM   #4
GasSavers_Red's Avatar
Nice job, congrats!
Old 08-05-2007, 09:28 PM   #5
cfg83's Avatar
baddog671 -
Hrrmmmmm, let's take a look :
298 miles / 3.82 gallons = 78.01 MPG
Now, remove the 90 miles of EOC :
208 / 3.82 = 54.45 MPG
Since your previous tanks were in the 50's, the 90 miles EOC definitely shows in the numbers. Were you already EOC'ing in your previous tanks?
Congratulations!
Old 08-05-2007, 10:10 PM   #6
Hockey4mnhs's Avatar
WOW nice gotta love the eoc! it really makes you want to hypermile when ya get tanks like that dosent it?
Old 08-06-2007, 12:04 PM   #7
GeekGuyAndy's Avatar
Nice! I hope that trend stays for more tanks. That is a small amount of gas, so your error is likely high, but no matter what the error is you have certainly improved a ton.
GeekGuyAndy is offline   Reply With Quote
Old 08-06-2007, 12:23 PM   #8
brucepick's Avatar
Nice going!
FWIW, I typically filll up about 4 gal, sometimes about 6. Results are pretty consistent as long as I fill up at the same station. Since I have no Scangauge or SuperMID I like to top off frequently so I can get the "feedback" re. how I'm doing.
So I wouldn't worry that the "short" tank threw off the results.
I think the nice mpg is due mostly to your diligence and hard work.
Old 08-06-2007, 12:48 PM   #9
Nice job. Congratulations.
Old 08-06-2007, 01:00 PM   #10
Any errors would show up in the long term calculations anyway. I don't think short fills are bad, especially if someone doesn't drive often and doesn't have a scangauge since there's no other way of checking their FE.
Coasting in gear NOT neutral gingermolloy General Fuel Topics 8 04-10-2010 08:29 PM
