s10 (s15) economy - Fuelly Forums
Old 05-03-2007, 04:56 PM   #1
s10 (s15) economy
hi all, i just traded a couple of three wheelers for an 83 gmc s15. the engine (2.8 liter) is bad, but it has a 4 speed and 3.08 gears in the rear.
it is an extremely ugly truck, but that doesn't bother me none.
the previous owner couldn't tell me exact mpg numbers but was pretty sure it was around 18-20.
i was thinking that i could put another engine in, new fluids in it, do a grill block, electric fan (its current fan is solid, not even a clutch) an alignment, recurving the ignition timing while adding a hotter coil, and replacing the rochester POS with a weber Progressive that i have, dual exhaust and maybe eventually an RV cam it it seems like it would be worth it
I would much rather have a 4.3, but i would have to put bearings into an s10 t5 that i have, but i would probably need a different clutch/flywheel and a bellhousing as well.
does anybody know what these usually get for mpg? any guesses as to what i could get it up to?
1987 volvo 740 turbo
smokes like a freight train!
~20.68 mpg
gasssaver87 is offline   Reply With Quote
Old 05-03-2007, 05:02 PM   #2
rvanengen's Avatar
Way back when (late 80's), my father had an 84 S-10 Blazer 2.8 5-speed that seemed to be getting about 22 on the highway.
-- Randall
McIntyre's First Law: "Under the right circumstances, anything I tell you may be wrong."
O'Brien's First Corollary to McIntyre's First Law: "I don't know what the right circumstances are, either."
rvanengen is offline   Reply With Quote
Old 05-04-2007, 12:03 AM   #3
caprice's Avatar
ouch Bite the bullet Go for an "iron duke" 2.5 4 cylender. very common in other cars besides the s10 (translation: easy to find at the salvage yard). Plus "no one likes them" because it has the "weaker" engine. (translation: costs less to buy.) Save weight and friction, install a S10 manual steering box, if not equiped. You will apreciate narrower front tires though!
With a 5 speed and TBI:
24 City
30 Highway
Better milage than my Daewoo Leganza! haha How sad is that?
I am starting to wish I put a used iron duke in my caprice. The car weighs the same as a s10, and more areo dynamic than a truck. It would would compliment a 6 speed transmission very nice! That definatly would be "out of the box" a 30+ MPG from a oversized car! I never need the power from my 350 anyway.
David
85 Chevrolet. 30 MPG or bust!
caprice is offline   Reply With Quote
Old 05-04-2007, 05:31 AM   #4
I was thinking Iron Duke too. But it sounds like maybe he wants a little more power.
The Caprice came with a V6 in the '80s, I think. Maybe one of those would be an easy swap?
Old 05-04-2007, 05:37 AM   #5
BumblingB's Avatar
There's always the possibility of a "sloped" bed cover. I keep hearing people rave on about how it netted them huge increase on HWY mpg.
BumblingB is offline   Reply With Quote
Old 05-04-2007, 06:07 AM   #6
I'm working on a belly pan for my and might have it done in a few days. I'll post pics when it's down. I think, and Phil Knox does too, that the belly pan will net better results than a sloped cover. A truck's underside is a aerodynamic engineer's nightmare. There's no attempt to smooth anything. The flatest surface is the gas tank and the rear bumper and frame members looks look as though they probably act like a drag chute for any airflow that makes it that far back. It's a mess and I can't wait to see what this does for my highway mileage.
John David
jdham137 is offline   Reply With Quote
Old 05-04-2007, 07:17 AM   #7
Celebrity Engine?
Is that the one they put in the Celebrity? If so the Auto-trans is real bugger to repair...
Old 05-04-2007, 07:18 AM   #8
lovemysan's Avatar
I put a good many miles on a 93 s10. 2.8l 5spd It averaged around 24-26mpg hauling tools and misc stuff. Mostly rural small town driving. Its a tough little motor. My favorite of all s10 powerplants. At 200k with the original timing chain and something ticking in the motor it still got a steady 24mpg driven by my 19yr old brother.
02 Saturn SL
5 speed
for pics click the link below
[SIGPIC][/SIGPIC]
Old 05-04-2007, 07:30 AM   #9
Probably the same one but thankfully the S-10 would be a rear drive. I think that the iron duke was their main (maybe only) 4 cylinder until the Quad4 replaced it.
Old 05-04-2007, 04:07 PM   #10
I had an '85 GMC S-15 for many years, and with the 2.8L 2bbl engine I averaged just under 20 MPG almost invariably. Lots of city, would be around 18-19, lots of highway, 20-21. Most I ever got out of it was just shy of 24, but this was with an auto trans and 4WD. I'll echo the comment on the engine's reliability - it was pretty bulletproof. Very few issues right up to the 280,000 mile mark when I gave it away.
Maillemann is offline   Reply With Quote
fuel-up entry suggestion fugalaya Fuelly Web Support and Community News 3 04-12-2009 08:29 AM
Pulse and Glide? Pete7874 General Fuel Topics 24 02-26-2009 11:11 AM
Individual Fuel Ups Reporting 0.0 Odometer jlmasonwv Fuelly Web Support and Community News 2 09-17-2008 05:27 AM
MID Install SVOboy Experiments, Modifications and DIY 33 06-04-2007 10:27 AM
