Where can I get non-Ethanol gas - Fuelly Forums
Old 06-14-2007, 12:59 PM   #1
I was wondering where I could get non-ethanol mixed gasoline in Massachusetts? Every station I have been to in my hometown has the 10% mixture sticker on the pump...
mpg_maniac is offline   Reply With Quote
Old 06-14-2007, 01:08 PM   #2
Probably nowhere. It's replaced MTBE.
Old 06-14-2007, 01:47 PM   #3
Hockey4mnhs's Avatar
you dont have just regular? we usally have a pick form three types
Old 06-14-2007, 02:24 PM   #4
The pumps have a sticker on the bottom part that states the 10% Ethanol mix. It doesn't seem to be for a particular grade so I believe it is for all grades.
Old 06-14-2007, 02:31 PM   #5
ELF
ELF's Avatar
You will have to do some research in your state, ethanol use varies by state.
For instance here in MN all gas is E-10 except for a few stations that carry 91 octane gas with no eth. this gas is only for classic cars and motorcycle/ boats ect. That doesn't stop me from using it though. Some states have a choice, some have ethanol just in the 87 octane gas.
Old 06-14-2007, 02:33 PM   #6
I know Michigan gas is E10, even though some time ago our governor Granny mandated that all the stickers be removed from the pumps. I guess that's to cover the stations that didn't put the stickers on the pumps. E10 is the defacto standard. No getting away from it anymore, at least in the States.
davidjh72 is offline   Reply With Quote
Old 06-14-2007, 02:34 PM   #7
Why avoid it?
1. because, from reading in this forum I am seeing a reduction in MPG
2. I want to see how high I can get my MPG in my Corolla
Old 06-14-2007, 02:43 PM   #8
You don't have a choice in that part of the country. Sorry.
Old 06-14-2007, 02:53 PM   #9
That's what I figured.
One other topic that has me confused is fuel additives?
Is there something that works both with MPG and is actually worth it $$$ wise?
I've seen some posts in this forum and some say that it's a big scam and others swear by it.
Can someone eluminate me?
Old 06-14-2007, 05:41 PM   #10
zpiloto's Avatar
Originally Posted by mpg_maniac View Post
Why avoid it?
Although you can't test it because you can't get regular fuel. Your Toyota might be doing fine on E10. Toyota did a study and found that it did not have much effect on the small displacement motors. I looked and could not find it but here's another one that tested a Camry with no decrease if FE.
Coasting in Neutral Illegal??? 95metro Hypermiling 23 05-12-2006 05:50 AM
