Acetone - Page 6 - Fuelly Forums
Old 04-16-2007, 03:29 PM   #51
Let me add my grain of salt here ! Being a non-beleiver in any additives after many past experimentations without any effect on FE, not knowing why... I tried acetone last winter and... oh surprise I got 8-10 % improvement. What was my scientific method ? Well the best one .... feeling !!!!! Well not exactly, but I usually know in advance the FC I will get on a tank just by the way I drive and the route I take, speed, etc... And I rarely miss since 40 years. But when I do miss, I have to know why... and last fall-winter, I saw this 10% improvement... so I knew there was something different.
GasSavers_Antoine is offline   Reply With Quote
Old 04-16-2007, 05:57 PM   #52
trebuchet03's Avatar
Originally Posted by MetroMPG View Post
I'm not sure if Trebuchet was suggesting we lose fuel to evaporation if the tank isn't used up quickly? We'll have to wait until he chimes in again. I was under the impression modern cars have closed fuel systems.
e.
Slaps hand on forehead.... sorry for the memory lapse there I was in 50's panel truck mode (my father's restoration project) You're 100% right - my apologies :P
What is the lowdown on fuel system and/or engine damage? Isn't acetone the main ingredient in some type of commonly-found-in-the-gas-station engine maintenance fuel additive?(fuel injector cleaner?) And if so I assume that adding a few ounces to ten gallons of fuel can't possibly have a short term effect (I guess we might start asking questions about long term effects once the results are in)
I'm going to say damage is little to 0. Testing yourself is very easy -- just make sure to use fuel system hose - as it's not exactly rubber (I'm fairly certain it's a neoprene)
As far as the A-B-A testing, I can see why getting that second A would be very desirable, but is it necessary in order to get the test off the ground? Would the results from a first round of A-B tests with multiple makes/models in different climates it be significant enough to prove verifiable and repeatable effect?
No - think of it as the placebo test. You can get quite drastic before after results just by taking a placebo - this is why pharm. testing uses blind/double blind testing. The best test is more than one A-B-A cycle - to verify your results are consistent.
11/12
Old 04-16-2007, 06:47 PM   #53
I stiil think that I could be convinced by a series of A-B tests, if it was on a flat stretch of road, using a scangauge and cruise control. But that's just me.
Old 04-16-2007, 06:59 PM   #54
What about distance? I saw a test where someone was talking about 100 miles or so... I was thinking more like 6 miles total in a bi-directional run. Does that seem too short?
oh...and trebuchet03, when you said "just make sure to use fuel system hose - as it's not exactly rubber (I'm fairly certain it's a neoprene)" Did you mean to deliver the acetone to the tank? If so, why not a long funnel?
GasSavers_Phoenix is offline   Reply With Quote
Old 04-16-2007, 08:39 PM   #55
No, I was talking about if you wanted to do your own testing on how acetone effects fuel system components (damage wise) This way you don't find any old piece of rubber (from say... an old shoe) and assume it's the same material as your fuel lines et. al. components.
11/12
Old 04-19-2007, 11:42 AM   #56
rvanengen's Avatar
How about this for a test...
Why not have someone do a bench test on a couple different engines running in a lab setting. Doing so , you have controlled temperature, humidity, traffic, lead-foot syndrome, and the placebo effect, resulting in documented results.
Then if you are a believer, you have proof...and if you are a skeptic, you have proof.
--Randall
Concord, NC
-- Randall
McIntyre's First Law: "Under the right circumstances, anything I tell you may be wrong."
O'Brien's First Corollary to McIntyre's First Law: "I don't know what the right circumstances are, either."
rvanengen is offline   Reply With Quote
Old 04-19-2007, 11:48 AM   #57
--Randall
Concord, NC
Like this?
I've been trying to find a paper published by them... but I've only found that teaser news article
11/12
Old 04-19-2007, 03:29 PM   #58
kwtorbe's Avatar
I tried acetone for one tank in my HX. It is the tank that I got 43mpg in instead of 45....Boooo to acetone for my car anyway...
kwtorbe is offline   Reply With Quote
Old 04-19-2007, 03:49 PM   #59
ELF
ELF's Avatar
This is why acetone has a lot of negative feedback IMO , people try it once and that particular tank ends up as less mpg. One tank either up or down would not be proof that something is or is not working. Beside that fact that every tank your mpg will vary. The point is they try it once and come to there own conclusion that its not working, instead of trying another tank, or try a different amount or even a different brand of acetone.
Old 04-19-2007, 08:10 PM   #60
How's this for a test?
Vehicle prepped by running as close to E as possible and then adding 10.5 gallons to tank plus 2 gallons in a potable tank placed in vehicle that is mixed @ 2 oz acetone to 1 gal gas.
"A-A-A" each "A" consisting of a pair of bi-directional 2.6 miles runs, 5.2 per set
At end of "A-A-A", estimated 20.64 miles traveled (plus another 4 to get to the track, and considering that my vehicle gets about 25 miles to the gallon), tank should be down to about 9.5 gal
"B-B" same runs but with 2 quarts of premixed gas first added to tank, bringing the fuel in tank back up to about ten gallons and a total concentration 1 oz acetone per ten gallons
At end of set B-B, estimated 13.75 miles traveled on track, tank should be down to about 9.5 gal
"C-C" started by adding 2 quarts of premixed gas added to tank, total concentration 2 oz per ten gallons
At end of set C-C, estimated 13.75 miles traveled on track, tank should be down to about 9.5 gal
"D-D" started by adding 2 quarts of premixed gas added to tank, total concentration 3 oz per ten gallons
At end of set D-D, estimated 13.75 miles traveled on track, tank should be down to about 9.5 gal
"E-E" started by adding 2 quarts of premixed gas added to tank, total concentration 4 oz per ten gallons
At end of set E-E, estimated 13.75 miles traveled on track, tank should be down to about 9.5 gal
The idea is to see if there is any real change using acetone, and if so can the curve I saw at be recreated. Unfortunately, the best I can come up with for getting back to "A" again is to come back another day a fresh tank or two later and Repeat the same "A-A-A" test and then repeating the same concentration that yielded the best result and comparing the difference.
The other idea I had was to do this same test except with only one gallon initially added (instead of 10.5). I thought the unknown amount of fuel in the tank would pose a problem by being a relatively much larger amount to skew the concentration of acetone, but the benefit would be that after test "E-E" it would not take long to run the tank empty and then go for a full refill to get a return to "A" on the same day and conditions. BUT, although it would be heavily diluted, there again is the unknown quantity of fuel and acetone left in the tank even after running it out of gas.
This would take a lot of time to do so I am hoping for a critique BEFORE I commit to explaining to my wife where I will be this Sunday
request: add 3&6 month simple moving averages to the graphs. dudleydog Fuelly Web Support and Community News 2 08-19-2010 01:53 AM
Sort by MPG billcharlton Fuelly Web Support and Community News 2 09-18-2008 04:00 AM
Calendar picker for entering fuel-up date? delfuego Fuelly Web Support and Community News 1 07-19-2008 01:18 PM
o2 sensor brand durability? n0rt0npr0 Transmissions and Running Gear 13 05-05-2006 01:54 PM
