Cutting back on radiator drag - Fuelly Forums
Old 03-26-2006, 03:50 PM   #1
basjoos's Avatar
One characteristic of hypermiling is that you aren't asking your engine to produce large amounts of power. This being the case, my engine isn't putting out large amounts of heat and I shouldn't require the total area of my radiator, which would be sized for a worst case situation, to keep my engine cooled. Since the radiator is responsible for 5% to 9% of the car's total drag, I wanted to see how much of my car's radiator air intake I could block off without causing the cooling water's temps to increase under my normal driving conditions. Cutting down on the air flow through the grill would have two beneficial effects on reducing drag. It reduces the drag caused by the air flow through the radiator and engine compartment, and it reduces the turbulance under the car where the radiator air is exhausted. I currently have the grill blocked down to a 4" X 1" opening in the upper center of the grill, and the cooling gauge hasn't budged, even during a 35MPH, 800 foot climb in third gear up the mountain into North Carolina and while sitting in traffic. I'll continue to closely monitor the cooling temp as we move into summer to see if I'll need to open up the grill more as the outside temperatures rise. The result of this modification on my car, combined with some some other minor drag reduction mods and changes in driving style, has caused my MPG to rise from the usual low 50's I normally get at this time of year into the upper 60's (last tank was 69MPG). It'll be interesting to see where the mileage will go as we ease into summer.
On another subject, I haven't been able to log into the www.cleanMPG website, even though it says I am registered as a member. When I try to login, it says "Thank you for logging in" and then sends me back to a login page. On the home page there is a line that reads "If you have any problems with the registration process or your account login, please contact contact support", but clicking on this line takes me to another page where they ask me to login.
aerocivic.com
Old 03-26-2006, 03:59 PM   #2
krousdb's Avatar
I have had my radiator
I have had my radiator blocked entirely since January and have seen no ill effects. I expect to keep it blocked into the summer to see if there are any problems.
Congrats on the awesome tank! I'm jealous.
Also, I will relay your message to the cleanmpg admins. We will get you fixed up.
Old 03-26-2006, 04:33 PM   #3
krousdb's Avatar
Basjoos, Here is what I got
Basjoos,
Here is what I got from tom at cleanmpg....
ask him if he is going to cleanmpg.com or www.cleanmpg.com
I've heard using cleanmpg.com doesn't work and you need to use www.cleanmpg.com Also, you will need javascript and cookies enabled I believe.
Hope that helps!
Old 03-26-2006, 04:36 PM   #4
I have that problem with
I have that problem with college websites, pain in the ***. Good thing they all have rejected me so I don't need to worry about it.
Old 03-26-2006, 10:38 PM   #5
Matt Timion's Avatar
It would be nice if someone
It would be nice if someone could test the before and after MPG data of radiator blocking.
Is anyone up for the challenge?
I'm actually thinking of switching to a smaller radiator so that I can have a slightly warmer engine and block of the unused area.
Old 03-27-2006, 04:27 AM   #6
Re: It would be nice if someone
do you mean radiator blocking or grille blocking?
i tested grille blocking on my car last fall, and it netted a 2.9% avg FE improvement.
http://www.metrompg.com/posts/grille-blocking-part-2.htm
Old 03-27-2006, 07:56 AM   #7
zpiloto's Avatar
I had the same results as
I had the same results as MetroMPG with grille bocking. I contribute this to the higher engine temps and not areo benifits.
Old 03-27-2006, 08:58 AM   #8
grille blocking benefits are
grille blocking benefits are probably a combination of both aero and higher engine/transaxle temps.
when testing last fall, FE increased *immediately* after installing the block on my car, which i would not expect to see if it were strictly a result of temperature (since temps don't increase immediately, and take some time to stabilize at a new higher level).
of course if all your driving is low-speed, then the only benefits you'll see are temp-related.
cooling system drag accounts for a significant amount of a vehicle's total drag. i've seen figures as high as 33% of total drag for a turbocharged volvo (with multiple radiators/intercoolers), but it's normally lower on regular cars - 5% to 9% as basjoos quoted in the first post in the thread.
Old 03-28-2006, 12:24 AM   #9
philmcneal's Avatar
if you engine kill a lot
if you engine kill a lot then you don't have to worry about engine over heating right? But wouldn't that prevent the cooling system from circulating in the engine? How about that Oil?
basjoos and krousdb can you post pics of your block? I wonder if it distracts from the car's image?
Old 03-28-2006, 04:39 PM   #10
basjoos's Avatar
Since engine idle-stop is
Since engine idle-stop is SOP with hybrid cars and many of them have gone well over 100,000 miles with no engine problems, there must not be any adverse cooling or lubrication problems associated with stopping the engine for short periods of time. I have 200,000 miles on my current engine with no oil consumption problems.
I currently have clear tape over the openings in the grill, so you have to really close close to see that anything is different.
krousdb, I have been going to the www.cleanmpg.com site and haven't had any problems with accessing other boards. I'll keep working on the problem and see what I can work out.
aerocivic.com
Mobile App and Multiple vehicles? Furrner Fuelly Web Support and Community News 5 11-26-2012 08:03 AM
Fully doesn't always post to Facebook at fuels-up b1gted Fuelly Web Support and Community News 1 07-08-2012 02:14 AM
Spark plug mod zpiloto General Fuel Topics 56 08-28-2009 07:47 PM
Volkwagon Creates Fuel Efficient Prototype - 235MPG!!! Bunger Automotive News, Articles and Products 26 05-05-2006 11:59 AM
1989 Suzuki Mini Truck iburnh2o For Sale 0 04-02-2006 05:57 AM
